Driveshaft help
Old May 20, 2008 | 11:39 AM
Hopper's Avatar
Driveshaft help
Ok. Feeling like a tard here...
Trying to remove the rear driveshaft on my '03. I'm getting new u-joints, and I am having the driveshaft reballanced at a local shop to see if that will clear up some of the driveline vibrations.
I'm trying to figure out how to remove the rear driveshaft up near the transfer case. Does it just pull out of the transfer case? Never worked on this truck's driveline before, and have never seen a setup like this before either.
Old May 20, 2008 | 02:43 PM
HOV's Avatar
HOV
Yeah, IIRC there are splines that couple it to the transfer case. Just pulls out once you've unbolted the axle end and the bracket.
Old May 20, 2008 | 05:44 PM
Hopper's Avatar
Will I need to wory about AFT leakage, or are the splines sealed?
Old May 21, 2008 | 01:10 PM
Aggie007's Avatar
No ATF leak, if so you have a bad seal.
Old May 21, 2008 | 06:52 PM
Hopper's Avatar
Thanks. I try and remove that thing tomorrow. Wouldn't doubt I have a bad seal though, every freakin' thing else on that tranny leaks like screen door in a hurricane.
Old May 21, 2008 | 11:15 PM
dieselkan's Avatar
Not sure about the auto trans but removing the drive shaft from a manual trans will allow the trans oil to leak out. I would assume an auto would be the same.
Erska
17
Sep 24, 2010 12:35 PM
isbsinkinson
Jan 29, 2008 04:19 PM
wvtruckpuller
Sep 12, 2007 10:25 PM
