? on doing compression test
Old Apr 24, 2009 | 07:41 PM
White Ghost's Avatar
how do you do a compression test on a cummins ? what are the part numbers on on the tools required ?
Old Apr 24, 2009 | 10:45 PM
BigIron70's Avatar
Cummins Guru
What year?
Old Apr 25, 2009 | 08:36 AM
no_6_oh_no's Avatar
Leak down test rather than a compression test is the reccomended way to test. Compression test will tell you if you have a dead hole but not if there is excessive wear in the cylinder(s).
Depends on what you are trying to accomplish also.
Old Apr 25, 2009 | 11:36 AM
i need to find out if i have a bad piston or if it is an injector. i can't drive the truck to the dealer for them to hook it up to the dbr computer. the truck is a 04.5 with 341000+ mi on it . it pulls heavy loads on a daily basis.
Old Apr 25, 2009 | 06:26 PM
anybody have anything else to add ?
Old Apr 27, 2009 | 02:46 PM
quick1sr's Avatar
bump....also need to find out how...have an 04 with what sounds like a broken piston banging around and alot of blow by...
Old Apr 27, 2009 | 08:33 PM
i found that my truck drop a valveseat.i still would like to know. how to a compression test ?
marc eber
May 9, 2007 04:57 PM
Lil Mule
Jan 26, 2005 09:48 AM
Dr. Evil
Oct 8, 2004 11:33 AM
