Does my 6 speed need its fluid changed
Old May 3, 2006 | 08:31 PM
PEAKSTRYDE's Avatar
Got about 40k on 'er now, should I dump the fluid and replace it? I'm gonna put Redline in it when the time comes, just wondering if its time yet?
Willing to listen to ALL opinions
Old May 3, 2006 | 08:36 PM
MikeyB's Avatar
I would. Did mine at 20k miles.
Don't forget to clean the magnet inside the case.
MikeyB
Old May 3, 2006 | 10:49 PM
Hoss's Avatar
Thats MR Hoss to you buddy!
I need to do mine. I'm sitting at 67,000 miles right now and it's still got the original oil in the tranny. Still got the original Michelin tires too (I'm trying to make them last 70,000 miles).
I haven't changed the tranny oil because frankly I kind of dread messing with it. I guess I need to do it though.
Old May 3, 2006 | 11:44 PM
PourinDiesel's Avatar
Yes change it.
You'll notice the difference afterwards.
Old May 4, 2006 | 06:19 AM
five20too's Avatar
What type oil do you use for the NV5600? It only states Mopar Manual Transmission oil in the manual
Old May 4, 2006 | 06:21 AM
redline mtl!!
Old May 4, 2006 | 07:06 AM
MikeyB's Avatar
Pennzoil Synchromesh Fluid, Redline MTL or Amsoil MTF.
MikeyB
Old May 4, 2006 | 10:29 AM
Mexstan's Avatar
I was lazy and only did mine at 46,000 miles. The oil came of quite black which surprised me. Almost nothing on the magnet, just some ultra fine sludge. Installed Redline, but have not noticed that much difference so far. A little, but not as much as I expected.
Old May 6, 2006 | 08:46 PM
five20too's Avatar
How much oil is needed to do the change? I picked up one bottle of the Pennzoil. Thanks.
Old May 6, 2006 | 09:18 PM
Hoss's Avatar
I don't think one bottle is gonna cut it.
Old May 6, 2006 | 09:45 PM
MikeyB's Avatar
Going to need 4.5 qts for the NV5600.
MikeyB
Old May 6, 2006 | 11:11 PM
gsbrockman's Avatar
The Pennzoil will run you about half price compared to the dealer stuff; same fluid, different bottle.
You'll need a 17 mm hex head socket to remove the fill plug (tighten to 22 ft-lbs). You can either completely remove the left side (driver) PTO cover and clean the magnet & inspect (have RTV on hand) or simply remove the lowest (middle, 6 o'clock position) bolt...this is actually the drain bolt (tighten to 30 ft-lbs).
This pic should aid in whats involved. I used a 14 mm six point socket to remove the lower most PTO Bolt....this is also the drain bolt for the NV5600. After re-filling and test driving, the NV5600 felt as if it shifted slightly easier than before....lots of members on both the TDR & DTR sites have noted the same results as well.
All in all, it's a very easy job and requires little effort...it's easier than changing the engine oil & filter.
Greg
Old May 8, 2006 | 02:45 AM
Hounddog's Avatar
Did mine at 15k with Amsoils new MTL.www.amsoil.comdifferance in day and night on shift quality over factory fill.
Old Feb 20, 2008 | 06:04 AM
Mark Hodowanec's Avatar
I'm way pat due at 82K. When does the service manual say that the NV5600 oil should be changed? When do you guy's change the oil?
Old Feb 20, 2008 | 07:09 AM
MikeyB's Avatar
It doesn't. I can't find it in my manual either.
Personally I'm sticking to the 30k intervals.
MikeyB
