Do the 3rd Gens have a rev limiter?
Originally posted by realsquash
Actually, the 03/04's start to defuel at 2750 or so gradually down to some amount that isn't enough to keep the truck accellerating, effectively limiting the top RPM while you're in gear. It could be defeated with some ECM programming but nobody seems to be willing to step up (BullyDog!).
Andy
Andy
Don't mean to change the topic, but it is somewhat rpm-related.
I have an automatic and floored it to merge into traffic coming back from a 100 mile trip. I saw it shift at 3000 or 3100, which surprised me. I did feel the power fall off just before it shifted. What concerned me is that I started smelling the oil I changed before leaving which I never did before. It's been raining so I couldn't really check to see where it might be coming from.
Not being broken-in yet, could blow-by have pushed some out somewhere?
Originally posted by LinearX
I'd be willing to guess that if you ran the TST or Hot Juice with the defueling based on EGT function turned off that they would continue to dump fuel into the engine. I have no solid proof to confirm or deny that, it's just my assumption.
Andy
From the dyno charts I've seen the TST doesn't do anything special up there. It defuels on EGT but that's 100% different than what the truck would normally do. The TST and I suspect the Juice, also, follow the stock power curve up there. They don't seem to do anything to try and defeat the defueling starting at 2750.
Andy
Andy
Here is the graph of my truck that I was looking at to get my numbers. This was done on a Dynojet when the truck just had intake and exhuast. I've yet to dyno again with the BDDL, though.
For all intents and purposes you can disgregard the green line on the graph. That was a 6th gear pull just to see what affect it would have on overall power. I found it interesting that the toque number is way up under 2000rpm, but then it begins to match the 5th gear pulls that I made first.
Ok, enough of my armchair analysis.
Nope-I'm relying on what the engine is rated at by the manufacturer. I guess it could be wrong-it wouldn't be the first time that an engine made peak power at an rpm somewhat lower than the rating specified. I will say though that my truck does not feel like it defuels until about 3000 or so, however unscientific that may be.
ARAcummins
Oct 24, 2004 09:30 PM
