Do 2500 rear lowering kits exist?
Hello folks...lurking for awhile, bunch of good insight from this site...I,ve been searchin for a company that has anything to drop the back of a 06 2500 mega...what have people been doing to get the rear down a few inches...are there shackle and hanger kits like 1500s??..i have had no luck finding anything in reguard....thanks for the help...here is a link to the pic of the ride...new post, i'll get better at it!
https://www.dieseltruckresource.com/...hp?photo=25514
Not sure if the Megacab has the same rear spring/block setup as the regular 2500/3500, but this is a simple way to drop about 1.8" at the axle. I have done it on mine, simple and no cost, just a little labor.
http://www.klenger.net/dodge/lowerin...d/slide01.html
thanks!. ..i have seen that write up...but it is a 2 wheel drive and has no spacers, i have thought of removin the overload spring for 1/2 to 1 inch drop....i dont tow heavy loads or have much weight in the back..but would like 2+ inches lower....
i would like to have a slight rake forward...at this point 2 or 3 inches would be great....i dont want to mess with the front any, the back is way high and dont like the look of the huge wheel well, thanks
I dropped mine about 3.5'' in the rear so the truck would sit level. AIM Industries had to custom make lowering shackles for my mega, but they should be a standard item now. The shackles were worth about a 2.5 drop. I also removed the bottom leaf, and the overloads to gain an additonal inch. I added Air-Rite bags replace any lost load capacity, and the truck rides really good now without being too soft. If you decide to go with the shackles from AIM be sure they understand it is a Mega/Diesel or you will get shackles for a regular or quad cab which are different. Also make sure the bushings are for the large ( diesel size ) shackle bolts. I probably have the invoice at home with the correct P/N if you need it, but I'm sure if you call them and stress the things I mentioned you will be fine.
thanks loco....sweet ride there too....i knew i shoulda went dually....
how loud in cab is your exhaust tone....i have been considering side exit b4 tire..but need to be somewhat quite inside...might keep stock muff...
Not much louder than stock when cruising, but you can hear it when you stick your foot in it. I kept the mega only resonator, and I'm glad I did. It seems to help with the drone. I cut my exhaust pipe off just past the rear end, right before it makes the turn towards the pass. side. Exhaust goes down towards the ground and keeps the soot off the back of the truck. This also keeps a clean uncluttered look from the rear of the truck which suits my taste just fine.
loco.breath, thanks for posting up about aim industries. I gave up looking for a shackle for our trucks. I was told it couldnt be done! I hope the shackle you got works on regular 2500's. I just ordered it.
