DIY Rear Brakes, 04.5 3500 Dually
If you are installing new calipers ignore this. You can also get caliper pins and rubber boots. I find the boots commonly break and allow water to rust the pins. They are cheap to replace at the same time and ensure the caliper floats like it should.
I just had to do rear calipers again. As with the last time the left, driver's side, failed. O'reily's did swap them, no issue. What I'm finding is that many of the lifetime warranted parts suppliers have begun changing their idea of what constitutes lifetime. They'll swap them once, and the replacement has from a 30 to 90 day warranty and that's all you get.
What happened?
I did everything as you said (except anti-seize compounds). Installed new rotors, calipers, and bled brakes. Now the rear brakes don't work. Is there something to do with the anti-lock brake system to reset it, or did I miss something?
2005 3500 RAM Laramie 5.9 Cummins Long bed crew cab dually.
Nice write up.
I am at 145k miles.
My pads are thin. but theres no pulsation on the pedal.
Would you pad slap it? Or go all the way in and turn the rotors and replace seals and parking break shoes?
Are people replacing wheel bearings on mileages like this or leaving them alone?
Thanks,
Chris,
I am at 145k miles.
Thanks,
Chris,
Just finished a rear brake job on my '04.5 3500 Dually. Definitely a project for those with some experience, not beginners. If you're taking it on, make sure you have all the right tools, especially a 1/2" impact wrench, and take your time with safety. The hardest part was dealing with the parking brake adjusters—passenger side was straightforward, but the driver's side was a bear. Also, don't forget to chock your front wheels and use sturdy jack stands. Managed to save a good chunk of change doing it myself, but it was quite the workout! If anyone needs detailed steps or has questions, feel free to ask.
38 Cigarette
Aug 26, 2010 03:33 PM
subspd
Aug 27, 2006 02:17 PM
