differential questions
Old Sep 8, 2010 | 06:12 PM
fastlane's Avatar
I just changed the oil in the front and rear diffs, in the front I found several small chunks of gear, less than an 1/8th of an inch. Not much stuff on the magnet. Should I be worried about that?
In the rear everything looked fine. oil looked burntish gold still
I was doing some research here before doing this, and I must have got my info mixed up. I used 85w-140 per my grandpas recommendation in the front and rear.
I just looked at the book and it says for 2003 and newer use synthetic 75-90, how important is this? can I drive it two more days before I change it, if i need to? this is the first time I ever changed the oil in the diffs of any truck I have owned I knew I was going to mess something up!
Old Sep 8, 2010 | 06:29 PM
Fiftygrit's Avatar
If it was me "yes" I would be worried, if you keep it in 2 wheel drive it wont hurt, but I would be thinking about changing out the ring and pinion, and yes I would replace the set, If you miss match gears you will get a whine. And I always use synthetic gear lube. theres a lot of heat generated in the diff`s especially the rear, as it is used all the time. good luck
Old Sep 8, 2010 | 07:34 PM
rockcrawler304's Avatar
Fiftygrit pretty much nailed it.
I would drain the front diff and also get a can of brake parts cleaner to spray it clean real good. Lift the front off the ground so you can spin the driveshaft (use jack stands ) and take a bright light and inspect it very closely. It may also be some diff casting and not gears. probably gears though but lets hope it's not.
You can drive a few days on the rear fluid before changing to synthetic with out any problems!
Old Sep 8, 2010 | 08:28 PM
tweeter123's Avatar
is that synthetic 75 - 90 recommended for 2 wd also and how much does one take
Old Sep 8, 2010 | 08:41 PM
Yes.
4 Qts will be enough. It is 3.?? actual quarts. If you have your owners manual it should say in there.
Old Sep 8, 2010 | 09:16 PM
tweeter123's Avatar
thank ya
Old Sep 8, 2010 | 09:19 PM
tweeter123's Avatar
any brand any better than others on the gear oil like lucas or amsoil or just local auto parts store. and a little off subject but i just had my nv5600 rebuilt got any good ideas on fluid to put back in it i just got it back today and waiting for clutch to arrive and wondering what best fluid to put back in it
Old Sep 9, 2010 | 09:02 AM
Shorts's Avatar
I use Mobil1 75w90
Old Sep 9, 2010 | 09:29 AM
JHardwick's Avatar
Originally Posted by Shorts
I use Mobil1 75w90
Same, except I use 140 in the rear. I've tried several different brands, but Mobile1 is the only brand that doesn't make my rear end chatter.
Old Sep 9, 2010 | 09:50 AM
AaronT's Avatar
For the NV5600 I use Pennzoil Sycromesh Trans fluid. This is what the factory fill was.
cwgtex
47
Aug 25, 2010 11:19 PM
DieselBD
Oct 16, 2007 08:33 PM
Mototrout
Oct 22, 2006 08:39 AM
broncobilly
Sep 4, 2006 05:23 PM
Graeme
Oct 25, 2003 09:26 PM
