Differential fluid, 75-90W synthetic, do you have to and where to get it the cheapest
Old Dec 8, 2006 | 03:16 PM
snowmanx's Avatar
How many quarts in the front and rear, I did a search but didn't find anything. Thanks.
Old Dec 8, 2006 | 03:24 PM
gsbrockman's Avatar
Lots of CTD owners run Mobil 1 75W90 or Valvoline 75W90, with a few using Amsoil or Royal Purple. I've had great luck with my Valvoline 75W90 Full Synthetic so far.
You'll need to buy 7 quarts......you'll have a little bit left over.
The re-useable gasket utilized on the AAM's is nice, too.
Greg
Old Dec 8, 2006 | 03:25 PM
reb0957's Avatar
I bought mine from AMSOIL.
Paid the $10 Preferred Customer price and it was about $2 a quart cheaper than the Royal Purple they had on the shelf at O'Reilly!
This is the one I used:
https://www.amsoil.com/storefront/fgr.aspx
Others are using this:
https://www.amsoil.com/storefront/svg.aspx
I put a little over 4 quarts in the rear and I have an 11.5" AAM
Old Dec 8, 2006 | 05:29 PM
truckjunkie's Avatar
If you DO decide to go Amsoil, do yourself a favor and spend the $10 or whatever on their little hand pump. That sucker screws right into the top of all Amsoil containers and makes filling the pumpkins, tcases, and trannys much easier.
I just R & R'd all of the fluids on my Wife's Pathfinder using that little contraption, and it did make life much easier.
Old Dec 8, 2006 | 06:04 PM
steelblitzkrieg's Avatar
DTR Detective
www.redlineoil.com/
Old Dec 8, 2006 | 06:20 PM
06megacabman's Avatar
I've heard the redline stuff is good also. I am thinking on using the Royal Purple brand. Anyone know if I have to add limited slip adder.
My sig shows the truck detail.
Old Dec 8, 2006 | 06:50 PM
DTR Detective
If your asking if you have L/S, couldn't tell by what you have posted, check your window sticker...It came with the TRX package and as a separate option, it would be itemized.
If your asking about the oil being L/S compatible, I can't speak for Purple, but Redline has their part numbers as follows...75W90 and 75W90NS (Non-Slip).
Old Dec 8, 2006 | 06:56 PM
Smkn600CTD's Avatar
Autozone has the Mobil1 75-90 oil.
Also, our trucks do not need a additive for the LS, only the 1500's require it.
Old Dec 8, 2006 | 08:41 PM
imaybail's Avatar
W#L M#RT has a full synthetic in either 75/90 or 75/140. Reasonably priced too.
Old Dec 8, 2006 | 09:01 PM
ed's Avatar
ed
If you use Royal Purple you do not have to add anything else. I bought mine on e-bay.
Old Dec 9, 2006 | 08:49 AM
bighornram's Avatar
3 qts in the front, 4 in the rear, has to be synthetic and GL-5 rated. Don't need any additives, 75W-90 or 75W-140. I got Mobil1 from Autozone for less than $10 a qt.
Old Dec 9, 2006 | 11:06 AM
Silver76's Avatar
No friction modifier needed with Royal Purple. On my 2002, I used RP with the friction modifier, and it wiped out the limited slip I had to run non-synthetic for a while to get it working again.
Old Dec 10, 2006 | 07:06 PM
moterhead's Avatar
No friction modifier or LS additive needed or even desireable with any full synth axle fluid.
I used Castrol the last time I changed mine.
Old Dec 10, 2006 | 09:27 PM
06dually's Avatar
I'll be changing both my front and rear diff. fluids in a couple thousand miles and will use 75w-90 Amsoil severe gear. BTW the amsoil is GL-5 rated as the owners manual calls for.
Old Dec 11, 2006 | 02:35 AM
TexasCTD's Avatar
Another vote for Mobil 1 75w90 from GhettoZone. Good stuff. Do not add any friction modifiers.
alaskanassassin
Jan 10, 2009 10:09 AM
digbog
Feb 13, 2007 10:28 AM
coobie
Jun 24, 2006 10:21 PM
coobie
Nov 29, 2004 04:26 PM
jethroish
Feb 17, 2003 06:28 AM
