Where can I get synthetic steering fluid?
Old Feb 12, 2007 | 02:17 PM
digbog's Avatar
I went to a couple small local shops and they dont carry it. I havent tried the large chain parts stores yet. Anyone have any ideas?
Old Feb 12, 2007 | 02:26 PM
RowJ's Avatar
My local Autozone carrys it from Valvoline!
RJ
Old Feb 12, 2007 | 02:28 PM
dieselfan's Avatar
walmart, napa, advance, autozone, o reilly's all have it around here. i bought the valvoline brand.
Old Feb 12, 2007 | 02:40 PM
digbog's Avatar
10-4! Thanks.
Old Feb 12, 2007 | 06:04 PM
Fueling around's Avatar
Uh The Valvoline PS is not synthetic fluid just additives. Read the label.
Redline & Royal Purple offers true synthetic
Old Feb 12, 2007 | 06:14 PM
amartinson's Avatar
Ditto! The others are blends at best.
Old Feb 12, 2007 | 09:18 PM
NHRedneck's Avatar
you can use ATF +4 for PS fluid without any issues walmart carries that stuff Amsoil ATF is also approved for use in PS systems i highly recommend using a suction gun and flushing the system 2 or 3 times, rather than completely draining and refilling the system
Old Feb 12, 2007 | 09:23 PM
digbog's Avatar
Well dang!! I already changed it out. I used a turkey baster to remove the fluid. I know it wont get all the fluid out that way so I was goin' to do it again in a week or two. I did use the valvoline fluid and did notice that it said it was blended.
Old Feb 12, 2007 | 11:12 PM
bentwings's Avatar
I just did mine this weekend. Turkey baster and Valvoline Syn blend. Much smoother and the cold groan is gone. I'll do it again the next week end if it isn't below 0. Come spring I'll purge the system.
Lube guard worked great last winter but I can't find any now.
Old Feb 13, 2007 | 10:28 AM
infidel's Avatar
I'd be careful with that on pre '03 trucks. The owner's manual specifically states that the rubber components of the power steering system aren't compatible with ATF.
Totallyrad
Jul 19, 2011 07:41 AM
Tommy93w350
Jun 26, 2007 04:42 PM
snowmanx
14
Dec 11, 2006 02:35 AM
4x4
Mar 26, 2003 12:41 AM
