Difference Between 555 & 6X0
Old Oct 3, 2005 | 08:23 AM
PsRumors's Avatar
What is the difference between the 555s and 6x0 engines? Is it all electronic or are there mechanical differences?
Old Oct 3, 2005 | 09:07 AM
RamWheelsBy4's Avatar
I believe that there are a number of changes, both mechanical and electronic. Different turbo, wastegate, exhaust, pistons, rods, computer controls, etc.
Cummins propaganda sheet for the 600:
http://www.cummins.com/na/pages/en/p...urbodiesel.cfm
Old Oct 3, 2005 | 11:51 AM
bigblock2stroke's Avatar
In a nutshell, the 600/610 engine was designed to meet the emissions standards imposed by the EPA for all diesel engines sold after Jan. 1st, 2004.
Lots of difference from the 555 engine because of that. Good thing is no EGR like Ford and Chevy, bad thing is worse fuel economy from retarded timing and post injection.
Only going to get worse in January of 2007
Old Oct 3, 2005 | 10:41 PM
LinearX's Avatar
New pistons and rods as well? The rest of the stuff I can believe, but I can't imagine that they'd have to change the pistons and rods unless they went to a different piston that required a different length rod. Ah well...I love my 555.
Old Oct 4, 2005 | 12:19 AM
Just reading the propaganda sheet about the 600s. Maybe I did not understand the part about rods and piston bowls, so maybe that is a stretch. But it looks to me to be a very different engine than the 555.
The 2004 Cummins 600 Turbo Diesel builds upon this durability with:
In-cylinder combustion and diesel oxidation catalyst solution requires no exhaust gas recirculation components.
Gallery cooled high-strength aluminum pistons for durability and long life to overhaul.
Premium high strength inconel exhaust valves and high-cobalt stellite exhaust valve seats for durability and long life to overhaul.
High strength exhaust manifold with multi-layer gasket between head and manifold.
Forged steel fracture-split connecting rods.
Cummins applied its technology to provide an in-cylinder solution along with a diesel oxidation catalyst. Cummins developed a new piston combustion bowl and a high flow electronically-controlled wastegated turbocharger to better match boost pressure to engine needs to reduce emissions.
Old Oct 4, 2005 | 12:23 AM
LinearX's Avatar
Average of 350,000 miles to overhaul.
Proven technology: most components are carry-over, including the Bosch high pressure common rail fuel system optimized by Cummins controls.
The 555 engines had the oil cooled pistons like the 6x0 engines do. That was one of the differences between the SO and the HO engines. I would assume, then, that the rods are the same. I could be wrong, though.
Old Oct 4, 2005 | 02:20 PM
Both the pistons and the rods are different.
Yes, the pistons are noozle jetted instead of the SO's gallery cooling/lubricating. However, the piston bowl is tailored to the emissions package to avoid the EGR system.
The fracture split rods were actually copied from the D-max. I know, not what you wanted to here, but its true.
Old Oct 4, 2005 | 07:50 PM
LinearX's Avatar
Doesn't hurt my feelings that things are different. I'd rather learn the truth than just continuing to wonder and, in this case, argue incorrectly.
Sucks that Cummins is stealing designs from the D-Max, though.
Old Oct 5, 2005 | 10:16 AM
Fracture split rods cost less to make. Its a bonus that they are also stronger.
Old Oct 7, 2005 | 08:35 AM
Steve034x4's Avatar
From: North of the Frost Line....near Priddis Alberta
OK, so why does the 610's oil get black so quickly? The 555's didn't have this 'feature'. Anyone know what the engine is doing to build up that soot so quickly in the oil? Maybe if they figured out how to burn this soot we'd get the 555's better miliage.
Old Oct 7, 2005 | 08:48 AM
commonrail's Avatar
Yes there is a difference....~3 - 5 MPG!
Old Oct 7, 2005 | 08:59 AM
TreeFarm's Avatar
I noticed that when I checked my oil at 450 miles. I expected the oil to look almost as clean as new out of the jug. Instead, it looked like the engine had 100 hours on it.
Old Oct 7, 2005 | 10:36 AM
LinearX's Avatar
Third injection event, maybe? I know that it's the primary suspect for the relatively poor fuel mileage compared to the 555. Just a guess.
Old Oct 7, 2005 | 02:57 PM
gsbrockman's Avatar
Old Oct 8, 2005 | 05:20 PM
dmurdock's Avatar
lol, you ain't kiddin.
