Diff fluid coming out of the rear diff filler plug...
Old Dec 1, 2009 | 12:31 AM
banana's Avatar
Angry Diff fluid coming out of the rear diff filler plug...
I just changed my diff fluid in the rear axle and now every time I park uphill in front of my house, there is oil leaking out of that filler plug....
I did not overfill it - level is 1/2 inch below the hole (right where the mark is stamped into the cover) when truck is leveled - I triple checked. And it has nothing to do with fluid temp, etc.
The plastic gasket/washer looks good, no cracks, etc. (but obviously doesn't seal it).
I tightened it twice already and it must be at least 35 ft-lbs ...if not more... (more would make no sense IMO and spec is 32 Nm). {edit: I meant 35 Nm not ft-lbs}
I remember I had the same BS the last time I changed it. But I cannot remember how I fixed it...
Am I the only guy having this problem?
Where can I get a copper or aluminum washer to replace that stupid plastic one... I checked at Autozone and Kragen, but they are too small....
Old Dec 1, 2009 | 04:49 AM
madhat's Avatar
Administrator/Jarhead
Have you tried some pipe thread tape?
Old Dec 1, 2009 | 06:26 AM
dwainjohnson's Avatar
Smile
I had the same problem on my front cover. New washer from Oreilley's did not work. Teflon tape did not work. Applied a little silicone to the threads and the problem went away.
Old Dec 1, 2009 | 08:37 AM
Lost Lake's Avatar
Ditto.... Teflon tape will seal it.
Old Dec 1, 2009 | 10:01 AM
banana's Avatar
thx - will try the Teflon tape right now...
Old Dec 1, 2009 | 12:45 PM
michiganracer2's Avatar
I have found yarn works well. running ford 9'' gears in the race car we change them from track to track. instead of using silicone or a gasket we always use yarn and works very well. I have used this in many applications over the years. No reason to scrap gaskets on many items.
I run about 3 wraps around anything I am working with and it makes for a great gasket.
Old Dec 1, 2009 | 02:26 PM
jimbo486's Avatar
yarn huh? interesting. that sounds pretty trick. what kinda yarn are you using? any specific thickness or diameter?
Old Dec 1, 2009 | 02:39 PM
lol, Yes yarn. The guys at the tracks are always scraping silicone and pilling on more orange goop every time they change a gear. I only have told my buddys about the yarn and they love it.
As far as thickness I dunno, its a large ball of it that my Mother used to knit with. I have used the same roll for 10+ years.
I would guess it to be 1/8'' thick and use it on many applications now.
Old Dec 1, 2009 | 07:10 PM
banana's Avatar
Worked great... I used the yellow tape (made 1for gas and petroleum applications)...
Old Dec 1, 2009 | 11:41 PM
Highway 4x4's Avatar
Any leaks in the diffs, always check the vents for being plugged.
Old Dec 1, 2009 | 11:44 PM
banana's Avatar
where are the vents? I couldn't see a hose, etc. coming out of the housing....
there is a speed sensor plug (which I thought is an Elocker when I bought it)
NoSparkplugs
Dec 28, 2008 09:58 AM
carpenterje
Nov 23, 2007 11:53 PM
chinook9
Sep 9, 2007 05:57 PM
Steve034x4
Dec 12, 2005 08:21 AM
BearKiller
Nov 6, 2005 09:19 PM
