Di Pricol Pyro
Di Pricol Pyro
I'm installing a DiPricol pyro this week. In looking at the gauge & wiring harness I'm a little confused & hoping someone can help out.
The wiring harness includes black (12v) & white (ground) wires that are for the LED illumination. Is that all I need to connect to see the gauge at night? Is the 7ft harness long enough?
The gauge itself includes a bulb that is not installed by default. Is it necesary to install this bulb? What does it illuminate?
I would plug in the wires to test but I was sent a the wrong color gauge (which is going back) and didn't want to tear open the plastic to test
Thanks,
Ron
Thanks,
Ron
DI's
Ron,
We have an isntruction sheet which would have explained it all for you, the bottom line is hook up both the LED and standard bulb connection to your power source for you lights and you'll be all set.
Mark @ DPPI
Mark @ DPPI
Mark,
Thanks for the heads up. I planned the install for tomorrow so I'd like to take a look at your instruction sheet if that's available. I couldn't find it on your website.
Thanks,
Ron
Thanks,
Ron
lucey
Aug 7, 2004 02:38 PM
Mopar_Mudder
16
May 5, 2003 01:00 PM
ATEAV8GN
Dec 13, 2002 08:51 AM
