Crazy Idle Problems
Old Apr 24, 2009 | 07:06 PM
SkyHarborCowboy's Avatar
Crazy Idle Problems
When coming to a stop sometimes the truck will try to push the truck through intersection will all of your weight on the brake! The truck is an automatic and completely stock!
Old Apr 24, 2009 | 07:08 PM
The only code is P633!
Old Apr 24, 2009 | 07:23 PM
vj_M's Avatar
sticky injectors..? my buddys does this..hammer some 911 cleaner in there see what. happens
Old Apr 24, 2009 | 07:39 PM
My friend said they have tried injectors and the problem is still present!
Old Apr 24, 2009 | 08:01 PM
HotRodTodd's Avatar
Sounds like the torque convertor is staying locked.
Old Apr 24, 2009 | 08:02 PM
vj_M's Avatar
does the engine keep a rev? or does it idle down and still push the truck?
Old Apr 24, 2009 | 08:06 PM
vj_M's Avatar
thats where i was going with my next question.. senors..
Old Apr 24, 2009 | 08:08 PM
I'm so used to handshakers I think a locked up torque convertor sounds about right. He was telling me it was revving up but his friend told me it sounds like the motors bogging down but pushing the truck through the brakes.
I can't do a search with my iPhone can anyone tell me what the code is?
Thanks!!
Old Apr 24, 2009 | 08:20 PM
I believe the TC is only supposed to stay locked up in 3rd and 4th gear only. What sensor tells the computer which gear the truck is in?
Thanks
Old Apr 24, 2009 | 08:51 PM
vj_M's Avatar
P0633- Sentry Key Immobilizer Module (SKIM) not programmed into PCM.
Old Apr 24, 2009 | 09:07 PM
vj_M's Avatar
if the truck still starts its probley fine. its a secruity isssue
Old Apr 24, 2009 | 09:13 PM
wiskeyVI's Avatar
Funny this has come up. On the road today, my truck "beebed" a few times. Then it beeped and came out of Cruse, and then sped back up.
The Brake and ABS light came on.
I checked for codes when i re-fueled and it gave me a P code and listed "Invalid Skim Key"
This is the second time it has happened. The last two times the truck owould not start. One of those times I also think I had gelled fuel.
The fist time the dealer reprogrammed the key/security system.....
I was starting to narrow it down to the Turbo Timer, which has acted up at times, as it did today.
Do you happen to have a timer on yours???
Old Apr 24, 2009 | 09:27 PM
Not my truck trying to help a friend with his. His truck is 100 percent stock with 110k on the odometer.
From the symptoms I have to say 100 to 1 it's the TC not unlooking. Now I just need to figure out which sensor(s) control the lock up of the TC.
Old Apr 24, 2009 | 09:34 PM
HotRodTodd's Avatar
More than likely it is not a sensor. It could be something blocking the bleed off passage for the torque convertor in the valve body, if you are lucky.
More than likely it is the torque convertor itself, or the front pump cover has warped.
Old Apr 25, 2009 | 11:07 AM
johnh's Avatar
what truck does your friend have? i answered your other post assuming the truck with the problem was the one in your signature
https://www.dieseltruckresource.com/...d.php?t=241087
