Crank Case Vent Filter?
Old Sep 3, 2012 | 03:45 PM
carri56's Avatar
How often should this be replaced? What happens if you don't replace?
Thanks
Old Sep 6, 2012 | 06:59 AM
rufushusky's Avatar
The only thing I noticed was the persistent smell of rotella on mine. I guess if you go way too long maybe you pop a hose leading to it? I went 205k on mine, I am sure that is way too long.
Old Sep 10, 2012 | 09:18 AM
dezeldog's Avatar
The OPs question was 'how often this needs to be replaced'. That is my ?? as well
Jim
Old Sep 10, 2012 | 09:25 AM
rufushusky's Avatar
The only think I could find was for the 6.7.... not the 5.9.
They recommend 67k miles. However I believe the one on the 5.9 is more of oil vaptor accumulator than filter. Unless your noticing leaking or anything like that I would leave it alone.
This guy has 700k+ on his.
http://www.cumminsforum.com/forum/3r...r-5-9-a-2.html
Old Sep 10, 2012 | 11:46 PM
seafish's Avatar
The CCV on a 5.9 does not need to be replaced unless it is leaking from the O-ring.
The CCV on a 6.7 cummins is a diffrent beast due to it's intgeral role in the EGR system, and DOES need to be serviced at intervals.
Old Sep 11, 2012 | 07:39 AM
dezeldog's Avatar
Thank you for the follow up on the CCV. I was getting a little nervous as I have 345k on the clock and never changed it. Thanx again
Jim
Old Sep 13, 2012 | 08:42 PM
carri56's Avatar
thanks
yes thanks for input , my 5.9 has 155k on it so i should be just fine.
DodgeCowboy
33
Oct 25, 2008 02:34 AM
JSPulliam21
Apr 12, 2007 08:56 PM
Thundercloud
Nov 9, 2006 06:45 AM
dbossdiesel
Oct 17, 2006 03:04 AM
CTD NUT
13
Jan 4, 2005 04:34 PM
