Cp-3
Old Feb 13, 2012 | 07:58 PM
john40's Avatar
Cp-3
Will 30 PSI at idle harm a Cp-3? Thanks-John
Old Feb 14, 2012 | 10:00 AM
jhenson's Avatar
Wow....30psi!! What kind of LP are you running? I know the VP44 didn't like much over 20psi head pressure going into it and while I don't think 30 is too much for the CP3, if you can regulate the pressure down a little you will be just fine. My AD150 holds 18 psi all the time and that is well within the range for me.
Old Feb 14, 2012 | 10:41 AM
john40's Avatar
I'm running an Airtex E8845 on the frame rail after my 2 micron filter. When I installed it I didn't think the pressure would be that high. I was hoping for no more than 20. I may have to regulate it down.
Thanks for your reply-John
Old Feb 15, 2012 | 10:35 AM
tesla440's Avatar
I can't find my link to a search I did here. I think the CP3 will handle up to 100PSI input. But do a search to make sure my memory isn't fading.
Old Feb 15, 2012 | 11:31 AM
john40's Avatar
Tesla440-I just did a Google search and it appears that many are running 30 or more PSI. I think my 30# will be okay. Thanks for your response-John
Old Feb 15, 2012 | 12:12 PM
AH64ID's Avatar
OEM specs are -5 to +15 psi, unless it's an aftermaket one where the builder specifies more pressure I would turn it down to a max of 15 at idle. Added pressure can increase wear, it does add a couple of hp but for the average user you cannot tell, but you can tell when you have a shorter pump life.
Old Feb 15, 2012 | 12:39 PM
dodgediesel's Avatar
Industrial Injection recomends 10-12psi max on a single CP3 set up or weird little things start to happen.
Old Feb 15, 2012 | 08:32 PM
john40's Avatar
What are weird little things? Just curious-John
