Cost for new cp3?
Old Nov 21, 2010 | 08:48 PM
cvcook's Avatar
Cost for new cp3?
My son took his 05 to the dodge house in Oklahoma city due to a very noticable miss at idle only, other than that the truck runs fine, was told by the serv manager his rail pressure was 6k @ idle and 12k @wot and probably will need a new cp3. they said a new one is $2500 and another $500 or so to install it....so does this sound right? also the truck is a BONE STOCK 3500 6speed with 180k miles Thanks in advance
Old Nov 21, 2010 | 09:06 PM
Purplezr2's Avatar
I believe if I found the right part on dodgeparts.com the list price is like 1600. That said I found a couple on ebay, on was re-manufactured for 775 or best offer, I would say you can find it cheaper. I would go to cummins and see what there cost is, I know it will be cheaper then 2500
Old Nov 22, 2010 | 09:01 AM
mq105's Avatar
Call T&C Diesel. I believe they will sell you a pump for less than $1600.
You can likely do the install yourself; it's not too difficult.
Also, talk with Todd, or have some more testing done to make sure the CP3 is the problem before you replace it.
Old Nov 22, 2010 | 10:04 AM
truckjunkie's Avatar
dieselpowerproducts.com has them advertised for $850 new... I don't have any affiliation with the company - I just did a Google search for CP3 Dodge and CP3 Cummins and they were one of the results...
Old Nov 23, 2010 | 11:23 PM
OldSmokey's Avatar
Richard at Glacier diesel sells them for around 900 if i remember correctly. Install it your self its a half hour to an hour swap. Three bolts, one shaft nut, fuel supply, fuel return, high pressure supply, and fca connection.
Here is a write up
http://www.cumminsforum.com/forum/3r...r-cp3-diy.html
Old Nov 24, 2010 | 05:58 PM
JJPage's Avatar
Here is a write up
Before I let a Dealer replace my CP3, I would want something in writing, that if this does not cure the symptoms, I'm not paying, or they pay for additional parts and labor.... I hate Dealers, half the time they are guessing on your dime.
OldSmokey, your much quicker than I am, it would take me a 1/2 an hour just to get the left front wheel and wheel liner off the truck, so I can access the CP3. That is a good link you provided, Thank you!
Old Nov 24, 2010 | 07:19 PM
Hvytrkmech's Avatar
You are getting completely hosed.
http://www.thedieselstore.com/templa...VehNum=1112628
As previously stated they are not hard to do if you have only a slight amount of mechanical experience.
Old Nov 24, 2010 | 07:49 PM
homewrecker's Avatar
I would also be looking at the pressure relief valve and make sure its not bleeding off and causing the low rail pressure. Also verify that the connector tube nuts are torqued correctly. There are several things besides the inj. pump that could be the problem. Possibly a bad fca on the inj. pump. Not sure what performance shops are near you but it mightbe worth your time to find one and let the check it out.
Old Dec 21, 2010 | 06:21 PM
cvcook's Avatar
Got it fixed! It was the FCA, took 10 about minutes to replace. got it at Cummins for $105, Dodge house wanted well over $200
Old Dec 22, 2010 | 06:13 PM
85glht's Avatar
+1 on the pressure relief valve. I had mine go south on me... Luckily I was still on warranty.
Jethro6213
19
Jul 11, 2008 11:59 AM
jmccart
Jun 22, 2008 03:49 PM
pullin hard
Mar 18, 2008 03:57 PM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
megacabrule
33
May 10, 2007 01:07 PM
