Cost of an injector
Old Mar 20, 2013 | 12:58 PM
motopscycho's Avatar
Cost of an injector
Had issue with truck idling rough and smoking at startup. Put in a new air cleaner, fuel filter and dealer suggested a can of additive which was done last week. Ran a tank of fuel through it, some improvement but still not right. Dropped it off at dealer this morning and just got the call that the #6 injector is bad. Part is $750, labor $250 and tax $120. $1120 for one injector. Is this standard or a ripoff? 2007 5.9L with 105,000.
Old Mar 20, 2013 | 01:19 PM
ollie32's Avatar
Anything at the *********** is a RIP OFF. Thats insane. If your made of money go for it.
If your at all mechanically inclined it's not hard to do.
I bought mine at http://www.dieselpowerproducts.com, have had no issues what so ever. I can't remember if I bought Bosch or the no name ones. I seem to recall going with the Bosch ones. I did half at time due to financial reasons, the second time took me 2.5 hours on the street to do the front 3.
There is tons of info on here regarding changing them, tricky part from what I recall is alignment with the fuel tubes through the head. #6 is Tricky given it's location.
Old Mar 20, 2013 | 02:48 PM
BigIron70's Avatar
Cummins Guru
They sell reman injectors, I put one in last week and lasted one week before it went out again. Engine was missing and smoke again. Replaced it again under warranty. Try a Cummins dealer same injector half the price Save your receipt in case you get a bad one also.
Old Mar 20, 2013 | 08:07 PM
wiskeyVI's Avatar
Mine went down on the road, around Clarksville, TN.,
Limped into the local dealer.
They said it was an injector or gasket (with the wiring in it)...... yours is cheap compared to what I had to pay in order to get back on the road ASAP.
At least they had the arts in stock.
Old Mar 20, 2013 | 09:43 PM
Kach's Avatar
Anyone know what exactly makes our injectors cost 5-10x as much as a 2nd gen? I know they're a bit more complex due to the HCPR and whatnot, but jeez.
That's big bucks at the dealer! Do they really charge around 6 grand for a set? I started using Diesel Kleen with my fillup today hoping to get the maximum life out of mine -so far so good...
Old Mar 21, 2013 | 11:29 AM
Hector-BD's Avatar
Vendor - Former Vendor
750.00 for one injector is alot. We remanufacture stock injectors, and I can tell you they are way less then that with a full one year warranty.
Old Mar 22, 2013 | 10:30 AM
banyon's Avatar
$ 300 or less for a Bosh reman. Check Cummins or a good diesel shop. There are step by step instructions on doing it yourself if you look around.
Old Mar 22, 2013 | 10:09 PM
roughstock's Avatar
Ive paid less than 300 per injector when ive swapped injectors in trucks. they are pretty easy to replace. Ive actually changed a few in the middle of parking lots and drivewys
Landini1
20
Dec 24, 2009 10:32 AM
torque6
Jul 3, 2005 01:48 PM
erics76
Jan 22, 2004 09:30 PM
SjLingenfelter
Feb 3, 2003 05:17 PM
figure_9_pro
Nov 30, 2002 06:18 AM
