?? Coolant Zerex G-05 ??
Old Oct 14, 2005 | 11:42 AM
HOUTEX's Avatar
Did some searching on coolant questions,, it seems the common answer
for a coolant to purchase at auto parts store or Wally World is
ZEREX G-05. ANY OTHER SUGGESTIONS BEFORE I PURCHASE ??
ANY NEW INFO ??
I will be replacing about 2 gallons, mixing with the origianal stuff
after filtering.
Doing this because I found sediment/particulate in lower rad hose.
Not sure what it is but I don't think I want it in my system.
Maybe I should replace all coolant, not just filter the old ??
Old Oct 14, 2005 | 12:12 PM
Berak's Avatar
That is the only HOAT type coolant I could find that was easy to purchase.
Old Oct 14, 2005 | 12:39 PM
smiller's Avatar
I believe that the Zerex G-05 formulation is the factory fill, and is approved by DC. I don't think you could go wrong by using it, in fact I don't think I would use anything else.
Old Oct 14, 2005 | 04:08 PM
Marine's Avatar
Veteran: Marine Corp
Drain, flush, and refill entire system with new coolant. Additives in the coolant wear out. It is better to change it all.
I replaced the coolant with Shell Rotella ELC 60/40 predilute. It seems like a great coolant, and I just have to add a rejuvenator once per year I believe.
shonne
26
Jun 19, 2010 09:25 AM
Mark Hodowanec
Aug 20, 2009 07:26 PM
LFD2037
Jun 28, 2008 11:28 PM
expressfish
Feb 24, 2007 08:36 AM
Hairy1
Nov 29, 2004 04:26 PM
