Cool start (no start) issue
Old Dec 4, 2010 | 07:56 AM
cgoaks77's Avatar
That's right, 'cool'. If the temp outside gets below about 40 degrees, it will turn over, but not start.
If I plug it in, depending on how cold it actually is, for about 1/2 an hour, it will bust off with no problem.
This rules out an air leak in the fuel system.
I checked power to the air intake heater (ok), replaced air intake heater (old one got hot enough to burn me, but replaced anyway...wasted money).
If it were an injector, ip, etc., it wouldn't make any difference when I plug it in...right?
Is there some kind of solenoid or acctuator, etc. that could be causing the problem? Truck runs great and doesn't burn or make oil. Batteries are still strong and only about a year old and have tested ok.
Need some advise from all you experts on what to try next.
Thanks
Old Dec 4, 2010 | 04:15 PM
cgoaks77's Avatar
Anybody? Is there something that I'm missin?
Old Dec 4, 2010 | 04:57 PM
bigwheels94's Avatar
When it cranks, but doesn't start, do you get white smoke(raw fuel) out the exhaust? Put a volt meter on it while it cranks, & make sure the batt. voltage doesn't drop below 8-9 volts. If it does the computer is shuting off. Does it crank at a decent speed? You may have a bad starter that is dwawing too much amperage.
Old Dec 5, 2010 | 08:28 AM
cgoaks77's Avatar
No white smoke.
Old Dec 5, 2010 | 11:13 AM
That means no fuel delivery. Check the voltage while cranking. If it drops below 8-9 volts that is probably your problem. Got any codes? Lift pump, fuel filter all OK.
Old Dec 7, 2010 | 08:14 AM
cgoaks77's Avatar
If that were an issue, would it matter that it starts fine in warmer weather?
How is the best way (location) to measure the voltage you are talking about?
Old Dec 7, 2010 | 05:16 PM
I would check @ the battery terminals. Use some alligator clips & set the meter where you can see it when you crank it over. If it's good there try again on the starter post. Cold temps lower batt voltage, & increase the power required to spin the engine. The problem would probably be the starter drawing too much amperage just to spin itself. Also make sure you have good connections between the 2 batt's too. One will start it when it's easy, but thats why there are 2, for when it's hard. There could be a hundred things that could cause this. This is where I'd start.
Old Dec 9, 2010 | 09:06 AM
cgoaks77's Avatar
sure appreciate it. I'll start there.
dan123dbl
Feb 13, 2015 05:47 PM
Big Horn 06
Dec 9, 2014 06:27 PM
DDysput
May 5, 2004 07:44 AM
Varmint
Mar 26, 2004 10:40 PM
