computer reset? 04.5
Old Sep 25, 2010 | 07:08 PM
4nic8r#1's Avatar
Unhappy computer reset? 04.5
2004.5 3500 with banks six gun. about two months ago the stock turbo shelled. the truck shut down, installed new turbo and manifold this morning and the truck will not fire. got codes on banks pda, and got crank position sensor. changed that and still nothing. checked voltage at injectors and there was none. need help getting out of shutdown mode.
Old Sep 26, 2010 | 10:54 AM
BigIron70's Avatar
Cummins Guru
Check power and grounds on battery, the ECM ground is on left side battery, follow wire up from ECM make sure it is connected to battery ground.
Old Sep 28, 2010 | 05:40 PM
J BODY's Avatar
Banks 6 guns have been setting CPS codes from the beginning of time. Nothing wrong with the old one but you found that out already. Interested to know how you checked voltage at the injectors considering at what voltage they run at.
GasganoFJ60
Oct 21, 2007 11:02 PM
boomer
Nov 28, 2005 07:58 PM
Tommy93w350
Jun 24, 2005 10:01 PM
Ram1
May 16, 2005 02:07 PM
