Codes and Bucking
Old Nov 20, 2011 | 01:19 PM
man doore's Avatar
Codes and Bucking
I have a code that wont go away, P0336 the crank position sensor, I have replaced it with a cummins sensor. The issue still stayed, inspected the tone ring everything checks out...I clear the code and it comes back as soon as I start the truck. When starting the truck sometimes it will fire right up other times it just doesn't wanna start. While driving it bucks. Everything is intermittent.
Any ideas what I'm not looking at? I got to get this Fixed!!!!
Old Feb 26, 2012 | 09:32 AM
3500CTD's Avatar
Did you ever get your issue fixed? My '03 started doing the exact same thing yesterday.
Old Feb 26, 2012 | 09:51 AM
man doore's Avatar
Yeah i think i got it figured out...there was a bad signal wire going to the a/c pressure switch...and the pressure switch was bad. From what i gathered the 5 volt signal is shared through out the circuit so if one gets shorted out it could effect something you not expect.
Old Feb 26, 2012 | 09:55 AM
southpawslingr1's Avatar
My 05 is doing the exact same thing.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
cyclopshotrod
Mar 21, 2005 12:43 PM
More Power
Jan 25, 2004 06:44 PM
