Code P1754 -- Throttle Valve Actuator
Old Jan 23, 2014 | 10:18 AM
944racer's Avatar
My is doing the same thing and started on a very cold day here in the east on start up. Bought a new ttva (mopar) on ebay ($211) installed last night and no change. Can valve be stuck internal? At wits end...
Old Jan 23, 2014 | 12:40 PM
HorseHauler's Avatar
Ahhh dont say that! It happened on a very cold day start up as well for me. I hope it's nothing more expensive!
Old Jan 23, 2014 | 04:26 PM
944racer's Avatar
Took to trans shop today. They reset the codes, after I installed new TTVA, and after a few miles light came on and truck does same thing again. Taking it back on Monday for a service and band adjustment...hope they don't find anything inside pan.
Will give update next week.
P.S. Also had them adjust/tighten the shift cable/linkage...like new again, able to manual down shift!
Old Jan 23, 2014 | 04:45 PM
Thanks for the update. I'll be waiting to hear. I'll update as well if I figure anything out
Old Jan 29, 2014 | 10:15 PM
rigz's Avatar
I too have the same problem as of 1/28/14 noted in the thread P1751 and P1754. It got down to 0 here in Colo Springs when this occurred, does anyone know why the cold causes this part to fail? Its been colder than this before without any issues. I will replace the TTVA this week myself. Please let us know about the codes not clearing. My scan tool couldn't clear them either.
Old Feb 1, 2014 | 07:35 PM
rigz's Avatar
trouble seating ttva
Got my part today popped the old one out and went to put the new one in and i can get it lined up and started but can not get it seated all of the way. has anyone else had this issue? I tried pulling it down, using a pry bar but i still cant seem to get it to go down the last 1/4in or so. does anyone know if its safe to put a little bit of lithium grease or Vaseline? please let me know your ideas anything would be great.
Old Feb 3, 2014 | 01:12 PM
Prodart440's Avatar
Make sure to relearn the computer after installation. Leave the key in the on position for 30 seconds without starting it.
Old Feb 7, 2014 | 10:33 AM
944racer's Avatar
A little follow up. Truck has been going back and forth between code and no code. It will drive fine for a couple of days and then goes back into limp mode (late 1st gear shift) and then go back to normal. Now it is due for a trans service with band adjustment, so I am figuring to replace govenor pressure sensor when pan is down. Solenoid has been replaced a few years with updated version, so not sure if i will replace again.
Will post again when I cure it! Has to be soon because camping season is coming up quickly!
Old Feb 11, 2014 | 11:55 AM
chrism69's Avatar
I had the same problem for a couple of years now. Spent 3 grand chasing it and could not get it cleared up . I'm on my 3rd TVA , 1 valve body and an ECM. I ended up just getting a code reader from Auto Zone and every time it happens I pull over reset the computer and I'M good. Seems to happen 2 or 3 times a year. This works for me.
Old Mar 16, 2014 | 04:17 PM
Well I have an update on mine. Finally put in a new TVA last night. It seemed to have fixed that problem so far and has also reset my cel. Now I have other big problems. It feels like I have hunting or possibly slipping (I'm hoping hunting) all over the place in my lower gears. I just ordered a governor pressure solenoid and transducer and hope and pray it takes care of all my problems! This thing is driving me and my wallet insane!
Old Mar 18, 2014 | 12:04 PM
chrism69's Avatar
Did you relearn the TVA? That may be the problem. Good luck
Old Mar 18, 2014 | 03:24 PM
How do I relearn the tva? I thought it relearned itself?
Old Mar 19, 2014 | 11:06 AM
chrism69's Avatar
Im not 100% sure I had the dealer do it. There is a post above describing how to do it. I dont know if that is the correct way.
Old Mar 15, 2015 | 05:15 PM
jhmfl's Avatar
Help, Mine doesn't go down the last 1/4" as well. What did you dO
Hello:
I need your help please... What did you do to get it to go Down that last little bit.... Thanks in advance for your help.
Jack
Old Mar 16, 2015 | 10:04 AM
PWong's Avatar
Originally Posted by jhmfl
Hello:
Jack
Try at different shifter position: neutral or 1st gear.
Can't remember exactly which one.
