Code P0191
Old Aug 1, 2008 | 01:22 PM
Crankpot's Avatar
Code P0191
Fuel Rail Pressure Transducer Rationality.
Seems to be a common fault. My truck got the code at 11,000 miles.
Dealer (Massey Yardley, Stuart, FL) fixed it quickly with an ECM flash to 18-032-06
Tech said he has replaced two tranducers recently, but mostly flashes cure the problem.
Bob
Old Aug 1, 2008 | 01:42 PM
CD in NM's Avatar
I had that code several times. First time at 1K they replaced some valve, I did not get the name of it but it has to do with the rail pressure, think it was the relief valve. Second time at about 5K, they did a flash. Third time at about 7K, they replaced a transducer and I have not had the code/problem since. Truly a PITA making all those trips to the dealership.
CD
Old Aug 1, 2008 | 05:44 PM
chipmonk's Avatar
CD
pressure relief valve.
Old Aug 1, 2008 | 10:39 PM
BigIron70's Avatar
Cummins Guru
Reprogram PCM
There is a flash update for PCM for code P0191.
tomm
Dec 21, 2016 09:23 PM
runamuk
Dec 21, 2016 09:05 PM
ohioviper
Aug 14, 2008 09:45 PM
MegaDawg
Jun 1, 2007 05:59 PM
ptgarcia
Jan 15, 2007 08:46 PM
