Clutch issue??
Old Oct 3, 2011 | 10:22 PM
glowball's Avatar
Clutch issue??
So my truck is starting to have a real hard time shifting gears. Especially down shifting. Does not slip at all. I tried making it slip and it won't. I've got an aftermarket clutch (sb con) with roughly 100,000 miles on it. Have 190,000 on the truck. Have not done the master slave set up. Wondering if that could be my issue? Any thoughts?
Thanks
Kris
Old Oct 3, 2011 | 10:53 PM
gadget.35-06's Avatar
Inspect the release system for leaks(easiest) then dig deeper(for things like a warped disc or pressure plate).
Old Oct 4, 2011 | 12:55 AM
rich's Avatar
when was the transmission serviced.
Old Oct 4, 2011 | 09:20 AM
glowball's Avatar
Only thing I've done to the tranny was change the oil. Put amsoil in it a long time ago. checked the oil and it looked good.
Old Oct 4, 2011 | 12:01 PM
rockcrawler304's Avatar
You say "real hard time shifting gears" as in it grinds when trying to shift or just hard to move the lever and no grinding?
Old Oct 4, 2011 | 01:54 PM
glowball's Avatar
No grinding. Just doesn't want to go in. Lot of pressure to get it in.
Old Oct 4, 2011 | 01:58 PM
mattk50's Avatar
could be the throw out bearing-----this was the issue with my stock one when i replaced it with 210,000 a couple of months ago
Old Oct 4, 2011 | 03:17 PM
Before you pull the tranny out to inspect everything, I would spend a little and upgrade the hydraulics first. Your stock set up might be getting weak and possibly leaking internally.
Old Oct 4, 2011 | 03:51 PM
glowball's Avatar
You mean like a new master cyl?
Can't find any leaks anywhere. Feels like I'm just not getting the clutch pushed in far enough. At a stop. I can barely get it into reverse. Pumping the peddle helped.
Old Oct 5, 2011 | 04:43 AM
rich's Avatar
if pumping the peddle helped theres your answer sounds like hydro's are getting week.
Old Oct 5, 2011 | 10:09 AM
Originally Posted by rich
if pumping the peddle helped there's your answer sounds like hydro's are getting week.
^^^ This!
Old Oct 9, 2011 | 05:02 AM
papaduck's Avatar
The leak is internal and will not show on the outside.
Old Oct 9, 2011 | 09:01 AM
PWong's Avatar
Would try replacing master and slave cylinder and see----.
Old Oct 10, 2011 | 09:59 AM
glowball's Avatar
Putting a new master slave in tomorrow. Clutch peddle feels a little different. Almost like the cyl I'm pushing in is hanging up just a tad. I'll let ya know if it fixes it.
Thanks
Kris
Old Oct 13, 2011 | 08:25 PM
glowball's Avatar
Wasn't the slave/mstr cyl. Frig!!! Guess I'm throwing a new clutch in it. Buddies dad is a really good mechanic and he is leaning towards a pressure plate hanging up. Just my luck.
