Clunking/Popping Noise!!!!!!!
Old Apr 23, 2007 | 10:25 AM
Buckshotmckee's Avatar
Angry Clunking/Popping Noise!!!!!!!
I'm really getting flustered with this new truck! It has developed a popping/clunking noise coming from the (R) front of the truck! It sounds like it's coming the trailing arms or the swaybar. Anybody had this issue???
Old Apr 23, 2007 | 10:36 AM
steelblitzkrieg's Avatar
DTR Detective
I have it, it seems to be while turning slightly in my case, hard to duplicate. I thought it was speed bump related but I've had it happen on flat sloped ground? It's almost a knock like 4x4 on dry ground, but it doesn't seem binding and not as loud, but I can definitely feel it. The wife can't hear it from the passenger seat?
P.S. Mine sounds like it's on the driver side though.
Old Apr 23, 2007 | 02:13 PM
JohnInNH's Avatar
Pop your front differential cover... and see if any "bits" fall out.
My truck made a bang a while ago. I thought I hit something in the road... Fine since... 3000 miles..
Then Sat I was coming to a stop rolling along at 4 mph and BANG! What the heck? Then clunk clunk..... This ain't good!
Seems a bolt backed out and went through my ring and pinion the last time busting a tooth off. Was floating around for a while..
Thought I kept occasionally hearing rocks getting tossed from my tires hitting up under my truck.
Old Apr 23, 2007 | 03:01 PM
XLR8R's Avatar
Have someone watch the trackbar-frame mounting bolt to see if it moves laterally while you turn the steering wheel back & forth (you probably won't see it with the wheels off the ground).
Honkylips
Oct 26, 2018 03:39 PM
Sleigher
May 25, 2012 12:03 AM
leeboy
Jul 3, 2010 01:55 AM
Honkylips
20
Jan 20, 2007 02:45 PM
carpenterje
Feb 16, 2006 09:21 PM
