Checking your hrs?
Old Oct 6, 2006 | 11:15 AM
JAXFL1's Avatar
Except for tell your overall MPH, what good is this? Why do I care how many hours are on the truck?
Old Oct 6, 2006 | 12:49 PM
036spd's Avatar
Don't push in the odometer reset and then turn on the key. The dash goes through a reset! Gauges and lights flipping on, thought I screwed something up! 55,850/1385hrs.
Old Oct 6, 2006 | 02:21 PM
GreyTD's Avatar
1 it is one factor the dealer uses to determine excessive idle time
2 some guys change oil by hour meter not mileage
3 overall average shows whether you mainly drive city or highway
4 because it's there
Old Oct 6, 2006 | 03:26 PM
GMScott's Avatar
255516 miles / 6163 hrs. = 41.459 m.p.h. Placed in service on 10/01/04
Old Oct 7, 2006 | 05:28 AM
TexasCTD's Avatar
That is some hauling booty right there. 255,516 miles / 24 months service = 10,646.5 average miles per month!!!!!
Think it will see a million before your done with it?
Any major break downs? Do you run any addititives in the fuel? What is your oil change interval and what type oil/filter do you run....if you don't mind me asking you these questions out of curiosity? Thanks.
Old Oct 7, 2006 | 12:03 PM
C Schomer's Avatar
036spd, I did that one time, right after fueling and I was waiting for the smoke to get out - It was psychedelic! Craig
Old Oct 7, 2006 | 01:30 PM
shep1's Avatar
Pull u 2, if I do this to check the hrs. will it reset the trip milage? Will it stay on hrs. or will it go back to the trip mi. function?
shep in DEnver.
Old Oct 9, 2006 | 12:21 AM
OR4ster's Avatar
69,500 miles and 1937 hrs. = 36 mph. Good stuff!
Old Oct 10, 2006 | 07:40 AM
JAXFL1's Avatar
OK I can go along with #2 "some guys change oil by hour meter not mileage" but why?
#1 How can the dealer tell the idle time from the hours? could be LA, CA traffic a 1 mile an hour parking lot with backed up traffic everyday of your work week, then the hours will be high but you have not been idleing, then again what is wrong with idleing?
#3 I know if I drive in the city or country or highway so what do I need the hours for?
#4 I have to agree with this one, but ?
Old Oct 10, 2006 | 08:33 AM
rockcrawler304's Avatar
181 hours and 7532 miles = 41.61 MPH
Thanks Pull U 2. One more thing I can keep track of on my truck.
Old Oct 10, 2006 | 04:11 PM
GreyTD's Avatar
jaxfl1 - #2 guys/gays who change by hour instead of milage are usually used to other machinery ( typically farms) that are slow running or idleing lots therfore oil is change when so many hours are put on it regardless of mileage. ie power genetors after so run time hours the oil is to be change, no mileage there.
#1 dealer will assume that when the hours are high and the mileage is low then you are ideling more than driving miles/hrs and thats only 1 check they do. It's bad on their part but it is a quick assement. Without getting into it there is lots of info on this board and others about why you should not idle a 3rd generation cummins truck.
#3 yes you know but so does anyone who checks the hours on that truck. average appears to be 36 to 38 miles/hr. if you are about this then you probably drive more highway than city. if you are below the the reverse is true.
#4 well what can say use it if want if not o well
Old Oct 10, 2006 | 09:25 PM
1-2-3's Avatar
Just a plain ole guy
So does it work on all models, or just gen 3's ?
Old Oct 10, 2006 | 09:43 PM
1-2-3's Avatar
Just tried my 99. It started with the word chec for a few seconds, then flashed every segment of the led in the odomoter, then bottomed all the gauges (everything, speedo and tach too), then centered all the gauges, then went to the high end of all of them, then showed all the lights. I never knew I had a tans temp light. But I still got no hour reading.
Old Oct 10, 2006 | 09:57 PM
53 willys's Avatar
sounds like you did the cluster check.
