Check Engine Light
Old Aug 2, 2006 | 09:52 PM
GARY WAYMAN's Avatar
Check Engine Light
CHECK ENGINE LIGHT CAME ON MON. WENT TO DEALER TUES. LEFT TRUCK
THEIR. DEALER CALLED AND SAID TORQUE CONVERTER OR FRONT PUMP.
THE TRUCK WAS RUNNING FINE. 15000 MI ON IT.CUMMINGS 05 325HP
I DID HAVE THE TRUCK SERVICED LAST SAT AT DEALER , OIL CHANGE,FUEL
FILTER,INJECTORS CLEAN, REAR END FLUID CHANGE ,15000 MI MAINTENCE
WHEN THEY CALLED TUES. THEY SAID THE WORK THEY DID SAT. DID NOT
CAUSE THE LIGHT TO COME ON . CANT BELIEVE TRANS. PROBLEM SO SOON.
WE PULL A 2 HORSE TRAILER ONCE A MONTH TO THE MOUNTAINS.
ANYBODY ELSE HAVING TRANS. PROBLEMS WITH LOW MILEAGE
FEED BACK WELCOMED THANKS
GW
Old Aug 2, 2006 | 10:07 PM
TonyB's Avatar
Gary,
Not sure if you are aware...all caps read like you are yelling!
To your question...6500 miles and no trans issues.
Was there any drivability issues? Anything you noticed other than the CEL?
Old Aug 2, 2006 | 10:28 PM
Tony, was not aware, truck has been running fine.
I live in gilbert,we pull a horse trailor to strawberry once a month
no problems.
GW
Old Aug 3, 2006 | 07:14 AM
HappyGA's Avatar
Go and turn your key on and off 3 times, and on the third time, leave it in the ACC on spot. Look at your odometer and see what codes come up. Let us know.
Old Aug 3, 2006 | 09:06 AM
TonyB's Avatar
Oh, Gary...Welcome to the site!
I'll send you a PM.
Tony
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
Fillerupsonny
Oct 9, 2002 06:01 PM
