changing transfer case fluid.
I've done the tranny, the front and rear difs, oil, since i'm on a roll, i might as well hit the transfer case. what fluids are you running? what is the capicity of the t. case? and helpfull tips appreciated. thanks in advance. p.s the truck has 22,000 miles on it.
Transfer case is not required until 60k miles. I did mine at 45k miles.
If you still want to do it, it uses the ATF+4 oil. Same as the transmission. I forget the quantity, but believe it is about 3 qts. or maybe 4.
The transfer case... both the NV271 and the NV273 takes a little over 2 quarts of ATF+4 transmission fluid. I use Valvoline ATF+4 because it is readily available at NAPA.
You will need a 10 mm Hex socket bit in order to remove the drain and fill plugs.
Are the fill plugs causing that many problems breaking free? If so, I guess some PB Blaster soaking overnight is in order to be safe? I should be doing mine pretty soon so thanks for the heads up.
Did mine this weekend. Remove the skid plate (4 - 13mm bolts) and it took about 2.5 qts (ATF +4). You shouldn't have any trouble removing the plugs but if the off chance that something did happen it is always best to make sure you open the fill plug first that way you are sure you can put fluid back in.
