Can bad tires mess up the rear end?
Old Mar 3, 2026 | 05:33 AM
Motorhead_22's Avatar
My front wheel bearing went out making the abs light come on for a little while thus shutting off the abs. Well that ruined the front tires and caused a few small flat spots in the tread in a few areas. Threw the tires out of balance I guess. Decided to rotate them to the back instead of just biting the bullet and replacing the tires. Now the rear end hums even after a new set of tires. Only thing I could see it doing was wearing out the rear wheel bearings. Anyways, after a few miles once the rear differential gets good and warmed up it starts humming a bit more than id like above 55-60mph. This is a 11.5aam on my dodge ram cummins. I dont notice any looseness checking the rear tires. Im at 255,000 miles running amsoil since new changed every 50k. It still looks like a nice golden honey color without any chunks on the magnet opinions? Just replaced the ujoints too. Opinions?
Old Mar 3, 2026 | 02:09 PM
mega-engr's Avatar
"California Style"
Rotate the tires and see if it is the same. Even new tires can suck...
Old Mar 3, 2026 | 02:41 PM
I took the jetski out today and gave it a good listen on the way home. Something about driving a different vehicle with different noises kind of resets your hearing if that makes sense. I think think half the noise is the front tires/wheel bearings and or both. Wonder if it would be worthwhile to just put 4 new good quality wheel bearings all the way around on this truck. At 255,000 miles only one has been replaced and that was a Moog that I swear is making noise again 50k miles later
Old Mar 3, 2026 | 05:09 PM
I noticed my $900 pair of michelins on the back werent balanced right. They have wheel weighted on seperate areas of the rim on one side. Its been about 15 years since I took an automotive class but it was my understanding this is incorrect, but it's doubt thats enough to cause the humming
Busboy
Oct 14, 2015 08:36 PM
35" 05'
Dec 31, 2009 09:41 AM
dodgebowhunter
Jul 13, 2008 05:56 PM
Happy
Sep 4, 2004 09:07 AM
