Blowby ?
Old Nov 20, 2005 | 02:56 PM
wap's Avatar
wap
Blowby ?
Is it normal for my truck to blow oil on my diff? Its not a lot but I was just curious, if this is not normal what would be the prob? Could someone explain to me exactly what blow by is? By the way my truck just broke 9,000 miles today if that matters.
thanks
Old Nov 20, 2005 | 03:00 PM
eric13's Avatar
Im pretty sure thats normal.
Old Nov 20, 2005 | 05:18 PM
Hounddog's Avatar
Front diff I would presume??? If so kinda normal.Check ENGINE oil and make sure not overfilled.
Old Nov 20, 2005 | 05:59 PM
siotwo's Avatar
I noticed a bit on mine during my second oil change. Wiped it off. Third change it wasn't there.
Old Nov 21, 2005 | 04:30 PM
white Lightning's Avatar
Blow by is when the pistons rings aren't sealing properly and the cmpression during the compression stroke escaped past the rings and sown into the crank case
Old Nov 21, 2005 | 07:55 PM
underwoodtransp's Avatar
what you are seeing is not blow-by. It is simply the crank case breather. It is from the valve cover it vents off excess pressure and a little oil vapor. Once away from the engine it gathers back into oil dropplets and deposits itself on the front diff and if you get enough like me it will catch on the rear one also. But still be mindful about the diffs so that they aren't actually leaking. But just enjoy the cummins!!
Old Nov 21, 2005 | 07:59 PM
Geico266's Avatar
It's an option you bought with the truck. It's the ULC (undercarrage lubrication system). DC put's it on all of it's CDT's.
A Cummins never leak, they are just marking their territory.
1ST GEN.
Jul 6, 2005 12:03 AM
I SPEED
Dec 20, 2004 03:17 AM
KATOOM
Apr 29, 2004 12:25 AM
SilverDiesel
Oct 10, 2003 12:55 AM
Evildiesel
Oct 29, 2002 05:22 PM
