big tires/tranny problems?
Old Jun 25, 2007 | 05:18 PM
joshworthy21's Avatar
i was wondering if anybody knew is it possible for 37" tires to make your tranny start slipping
Old Jun 25, 2007 | 05:23 PM
OOPS's Avatar
Did you change the gears in your diffs? If no then the answer is yes. Bigger tires changes your final drive gear ratio higher ratio, lower number. Which is hard on drivetrain componets.
Old Jun 25, 2007 | 05:25 PM
Pooter's Avatar
Shouldnt be that much of a problem driving around normally, but if you are running a box, and making some power, yes, kiss it goodbye if you are hard on it...
Old Jun 25, 2007 | 06:05 PM
hey guys thanks for the imput heres the deal i have only put about 750 mi on it sence lifted but last weekend i noticed as i took off from a stop that it felt like the trans. slipped a little in 1st gear @ about 15 or16 mph sense then i've noticed this enough times to scare me!! It shifts fine all the time except at that speed and when it starts to feel like its sliping if i let off the pedal a little bit or just push on through it its fine after that but its just weird that 750 mi after lift and tires i feel trans problems
so the trans sliping in 1st gear isnt a problem??
and if i regear like to a 4:56 you dont think it will slip any more
bigdrdge02
Off Road / 4x4
13
Nov 12, 2010 06:01 AM
1320
May 29, 2009 10:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
turbo6justin
Jul 4, 2006 10:36 AM
Captain
Sep 9, 2005 12:16 AM
