BD Low Fuel Pressure Warning Kit with Jacobs Brake
Has anyone installed the BD Power low fuel pressure warning light kit on a 2003 with the Jacobs exhaust brake? The concern is that there may not be enough room for the banjo bolt on the high pressure pump if you have the Jacobs exhaust brake vacuum pump installed.
Casey
Casey
Casey,
I have a fuel pressure guage mounted below the filter using the same banjo bolt supplied for mounting on the CP3. I did this because of the Jake vaccum pump. It works well and reads 5-8 psi on a Quadzilla Commander. I'd suggest not going with the tapped filter cover some recommend, because it reads on the inlet side of the filter and thus you cannot tell when the filter is restricting flow.
Just my $.03
Just my $.03
howe719
18
Oct 18, 2007 02:35 AM
OldSmokey
Sep 30, 2006 07:28 PM
SolarYellow05
Sep 10, 2006 09:14 AM
Maccandy
Mar 22, 2004 11:59 AM
