Battery charge question
Old Jun 22, 2020 | 09:32 AM
Mexstan's Avatar
Need new batteries and am thinking about installing AGM batteries. The reason I am considering AGM batteries is that I have an inverter in the truck that frequently nearly runs the lead acid batteries flat and that of course shortens their life. The AGM batteries can apparently tolerate more frequent deep cycling than lead acid batteries. Is there a problem with charging AGM batteries in these trucks? Am asking the question because I have a cabin in the woods that is totally off grid and notice on the charge controller that there is a separate setting for charging AGM batteries.
Old Jun 22, 2020 | 09:41 PM
TJAR66's Avatar
What about deep cell RV batteries. They are designed to be deeply discharged and recharged many times
Old Jun 23, 2020 | 07:04 AM
Mexstan's Avatar
Definitely a possibility, but in my part of the world they are very expensive. Switching to AGM batteries in this particular case is relatively inexpensive because my present batteries are still under warranty and the company (Autozone) will refund the full cost of the batteries and I only need to pay the difference.
Old Jul 12, 2020 | 10:16 AM
Green_Machine's Avatar
My experience with AGM is in boats. They are a fantastic battery. They last a long time and have very little self discharge compared to a flooded battery. They also typically support a large current discharge without issue. I am running them on standard alternators without issue
having said that, the one thing they don’t tolerate as well as a lead acid battery is coming back from complete discharge. If you kill them all the way, they are done.
They can be had in a higher amp hour per unit size though so you may be able to upgrade your amp hours.
I am partial to the Marathons. They make a hell of a battery
Chay
Old Sep 7, 2020 | 02:04 AM
bonus's Avatar
Go for the AGM,, i use Optima, even after everyone says NOT TO... My last red tops lasted 9 years,,, gonna get some new ones before winter. GOOD LUCK.
Old Sep 10, 2020 | 07:22 AM
Mexstan's Avatar
Went with the AGM's from Autozone. Use the same batteries in my off grid cabin. So far zero problems in the truck or cabin and happy with the 6 AGM's I bought
Old Sep 12, 2020 | 09:59 PM
bonus's Avatar
What model AGM you get? Reason I like the Red tops, lighter weight than standard batt.
Old Sep 13, 2020 | 02:21 PM
Mexstan's Avatar
I bought the 65-AGM. Wanted to use the Optima yellow tops for my off grid solar system, but they were ridiculously expensive, so ended up using the same AGM batteries that I am using in my truck. So far truck and off grid are working just fine.
stealman
15
May 19, 2014 01:54 PM
BoDiesel
Nov 25, 2009 03:05 PM
Falcon1
Aug 19, 2007 02:41 AM
billmac
14
Oct 7, 2004 10:40 AM
misterKTM
May 28, 2003 09:42 AM
