Ball joints
Old Jan 11, 2012 | 09:26 PM
southerman's Avatar
Ball joints
Got my truck back from my mechnic he is telling me I need ball joints badly all four. I have had this truck for about two weeks now should I call the dealership and tell them this or am I just pissing in the wind cause I bought this truck as is but I feel they should have caught this.
Old Jan 11, 2012 | 10:29 PM
torquefan's Avatar
The thing you have to keep in mind is that many technicians don't seem to realize that ball joints have a wear spec. These joints are actually allowed over .100" of axial (up and down) movement before replacement is required. Some shops will try to sell ball joints at the first sign of any movement. I'm not saying this is what happened here, but just so you are aware and can find out the story before you talk to the dealership. I would definitely ask this guy how much play he measured and how far over the spec they are. If you have numbers to go by, the dealership will have a lot less of a credible argument.
Old Jan 12, 2012 | 10:39 AM
jhenson's Avatar
Do you have any front tire wear? The first time I did my ball joints was just a hair over a 100k. I did have tire wear at the time but it turned out to be just an alignment issue. Just did ball joints again at almost 300k because both front tires were absolutely SLOPPY in the "play" department and I had severe tire wear this time. Went with the XRF's from TireClub along with the upgraded steering system and it drives like a new truck now.
Just jack the front end off the ground and check for yourself if there is any major up/down or back/forth movement to the front wheels.....if so, balljoints are the issue.
Old Jan 12, 2012 | 09:13 PM
southerman's Avatar
Just one border line ball joint took it dealership they were cool about it showed me on lift what truck was doing lucky head shop dude was a 4x4 rock crawler truck guy he showed me his truck he knew his stuff just need a alignment and tire rotations. Got a quick schooling on lifted trucks feel better now that my wheels wii not fly off.
Old Jan 12, 2012 | 10:22 PM
torquefan's Avatar
That's good to hear. They sound like a pretty decent shop.
firebill1720
20
Mar 5, 2010 09:23 AM
njmaier
15
Jul 26, 2006 07:43 AM
getblown5.9
May 2, 2006 10:01 PM
Seeder
Feb 15, 2006 08:15 PM
Dynocon
Mar 5, 2005 06:24 PM
