Baldwin PF7977 fuel filter, does NOT fit!
Hello,
HOW do you get the Baldwin PF7977 filter to fit straight on the fuel filter cannister top?
Over the weekend I was trying to replace fuel filters w/ a new Baldwin PF7977 filter.
It will NOT fit on the top!
It only goes on cocked, not straight, no matter how or what I try.
This filter is tapered, the part that goes on the canister top is larger than the bottom, correct?
The bottom of this filter has the hole, the top has a recessed depression.
I even tried forcing it between two 2x4s.
Amazing the top didn't crack or break.
Also, I can NOT screw the top back down w/ the filter in place!
Guess, I HAVE to re-use the old one, until I can get a new one.
What a total drag this was.
Maybe I got a bad one?
Anyone experience this?
Oh, this is w/ a 2006 5.9.
buggz - I installed the metal filter canister lid from Geno's, and have the same issue with all brands of OEM replacement filters. Easy fix - I just wrap a rag around the filter body to keep crap out, then use a file and just drawfile around the edge of the plastic top a couple times, or until it fits - takes about two minutes.
help! I cannot get the new filter to fit in the cannister top 5.9 cummings 2003 dodge
help! I cannot get the new filter to fit in the canister top. it is a 5.9 dodge deisal. i tried the baldwin, wix and a oen dodge/mopar filters all are to wide at top to fit in the cap.
