Anyone here dropped a valve?
Old May 10, 2008 | 10:09 PM
dozer12216's Avatar
The ARVIN gets hit occasionally.
Old May 11, 2008 | 07:09 AM
MikeyB's Avatar
Originally Posted by radshooter
This is a very interesting thread. My '03 only has 36k miles on it, but I intend for it to last forever. I do run an EGT guage, and try to limit myself to 1250 as much as possible. I tow an 18,000 lb. fiver pretty regular, and am religious about driving by the EGT guage. A lot of time I tow in 5th gear, RPMs around 2600. Is this considered too high of an RPM? I am very interested in how to prevent this from happening, if it can be prevented.
Couple of tricks to try if you want to lower the EGTs. One is installed an adjustable boost elbow and set it to around 32psi and install a boost fooler. The extra boost will lower the EGTs at WOT. Also can do the tone ring mod (search the 3rd gen performance section for more info) or install a Rokktech crankshaft sensor. Both will give about 2 degrees of advance timing and will help lower the EGTs.
Or buy a SMARTY. Not only will it increase the performance but will lower the EGTs with the right settings. I'm only seeing 1000 degrees at WOT with the SMARTY.
MikeyB
Old May 11, 2008 | 02:30 PM
GlennRMK's Avatar
I am only seeing 1000-1100 wide open at 70-80 MPH(acceleration from a stop) with the Smarty on Tow(70hp). This is with boost at about 28-30 lbs and 5000 ft elevation. Also have the Scotty III.
supersonictoys
14
Dec 1, 2007 04:04 PM
scout98
Aug 5, 2007 02:39 PM
Jeff K
Jan 15, 2007 07:05 PM
Warlord
Jul 23, 2006 10:15 PM
Swamp_Donkey
May 14, 2003 09:31 AM
