anybody know what a code 64 12 is?
Old Aug 1, 2003 | 08:57 PM
Mark Thomas's Avatar
found it today in obdc
Old Aug 2, 2003 | 07:13 PM
Crabjoe's Avatar
Re:anybody know what a code 64 12 is?
I've got a OBD2 scanner and all the codes I've seen start with a P. Even if I were to drop the "P" and just check the numbers the 1st digit only has a range of 0-3. Are you sure that's an OBD2 code? From what you've got posted it looks like a code my Jeep spits out when I use the ignition key in an on/off cycle to get it to kick me a code.
If it's done with the key it's as follows:
64. Catalytic converter efficiency failure.
12. Stand-by memory circuit fault. Direct battery feed to the LM has been interrupted.
Hope this helps.
Old Aug 4, 2003 | 08:42 AM
Chillimau's Avatar
How do you get a code out of one without a scanner? Will cycling the key three times will do it? Guess it would show on the odometer screen?
Thanks
Old Aug 4, 2003 | 09:57 PM
Crabjoe's Avatar
I have no idea on how it shows on a Dodge or even if it's possible but on most Chrysler vehicles, you can cycle your ignition key from off to on 3 times and stop on the on position to get codes. When doing this, do not start the motor. On my Jeep, it flashes the check engin light, but I understand that on vehicles with a digital odometer, it will just show the codes there.
Old Aug 5, 2003 | 07:21 AM
Chillimau's Avatar
Thanks, I'll give it a try tonight. I shouldn't have any codes right now. I thought that if I ever needed a scanner I might buy one, but if anybody has priced a DRBIII you will fall over and just go buy a new truck, DRBIII = $6000.00 . I know there are some "consumer grade" scanners such as auto x-ray, might try that if the need ever arises.
Thanks again
DISTURBED
Oct 7, 2006 12:07 PM
cawt0123
Sep 17, 2006 05:59 PM
fitzydog
Oct 11, 2004 03:08 PM
DC
Dec 5, 2002 09:34 PM
