Air Filter
Old Oct 25, 2009 | 10:13 PM
magnum783's Avatar
Air Filter
I know the description of this section says no High Performance question please do no think this is one of them. I installed a K&N Air Filter on my truck says I need to go back to the stock because the K&N filter is oiled and lets to much junk in. Anyone have a proposal of what to use to replace it with. Is there another Aftermarket one that will work.
Old Oct 25, 2009 | 10:18 PM
NickBeek's Avatar
Just use the stock paper element. The aftermarket filters don't have enough benefit to outweigh the risk in my opinion.
Old Oct 25, 2009 | 10:44 PM
rockcrawler304's Avatar
I run the Amsoil EAA189 dry cleanable filter. I drive in dusty conditions and have over 40k miles on this filter and have not had ANY post filter dust in the intake tube. (I clean it every oil change)
That's my 1.5 cents
Old Oct 26, 2009 | 10:29 AM
Guardrail's Avatar
Why do you want to go back?
Old Oct 26, 2009 | 11:34 AM
bansh-eman's Avatar
I run the autozone special. Never been one for the K&N maama jama
Old Oct 26, 2009 | 01:35 PM
DBLR's Avatar
Guess you missed this part of his post "filter is oiled and lets to much junk in"
Old Oct 26, 2009 | 01:41 PM
1-2-3's Avatar
Just a plain ole guy
Did you oil it? I do my K&N and take my time, letting it dry between cleaning and oiling steps and have NO ISSUES.
Old Oct 26, 2009 | 03:28 PM
92'1stGen's Avatar
Run the stock paper element, as said earlier it can't be beat for it's filtration capabilities compared to aftermarket options. Plus, unless your making over 500 hp, aftermarket intakes are a waste of money.
Old Oct 26, 2009 | 07:40 PM
magnum783's Avatar
I know everyone is saying run the stock one. I can't I pitched the components as i thought the K&N was the best thing going. I am just looking for another aftermarket one that will work for my situation.
Old Oct 26, 2009 | 08:41 PM
carl48's Avatar
you need to go back to stock. buy another one from this site from some one who has switched his out. most of the k&n i have seen lets hot under hood air in. if you want to do anything to the stock box go with a psm kit. you just restored several hundred thousand miles of life to your engine by dumping the k&n
Old Oct 27, 2009 | 08:20 PM
Hairy1's Avatar
From: Adirondacks of New York and Daytona Beach FL.
Dodge just came out with a high flow filter, uses same OEM box, filter element is like twice as thick. $30 something, I havn't installed it yet, will try it on drive to Florida 2nd week of November, will post how it does.
Old Oct 27, 2009 | 10:00 PM
magnum783's Avatar
Thanks for your advice I will look at going for a PSM kit as I did not like performance I got out of the stock filter box as I do not think I will go back to it.
Old Oct 28, 2009 | 05:57 AM
05HDRAM's Avatar
Cut a 4" hole in the bottom of the stock airbox and add a PVC elbow. I did this after reading some others on the board posted about doing this. Unless you are pushing big power numbers, this will allow more than enough air. I have used an Amsoil drop in and now a NAPA replacement and have no complaints. The only thing to watch out for on the drop in replacements is the rubber seal wearing / getting compressed over time. After a year or so, the seal on my Amsoil was compressing to much for my liking.
Old Oct 28, 2009 | 08:03 AM
MikeyB's Avatar
Is it the same filter used on the 6.7L?
MikeyB
Old Oct 28, 2009 | 09:00 AM
Lost Lake's Avatar
What's the elbow for? How loud is the turbo / intake now?
I agree with a turbo charger all the hype about air filters flowing is kind of moot. If the air vacuum gauge isn't in the red you're probably sucking enough air. Without a turbo it's a different story.
