air compressor
air compressor
Looking for information for a bolt on air compressor for a 2004 1/2, it needs to push 150 psi for train horns?
Any information would be greatly appreciated!!
Thanks
Thanks
From: In Oroville, Ca., same house for past 46 yrs!
Harbor Freight has one for around $60. but you really need a tank as well to hold enough volume to make the horns work properly. You can also go to the web sites advertising train air horns and use one of theirs but they're usually more expensive.
http://www.harborfreight.com/12-volt...sor-66399.html
If you already have the horns, contact a place like this...
http://trainhorns.net/
and ask if they will sell the tank seperately. Most usually will.
Which "train" horn are you installing?
I have a Nathan AirChime K3LA, 5 gallons of air, 175psi, manual valve, and an Air Zenith OB2 compressor. No inverter needed since it's all 12VDC.
Kilby makes one for the 3rd gen's ('03 - '06) and Extreme Outback makes one for the newer Cummins 6.7L engines and has kits for all gas and diesel engines.
I plan on doing the Extreme Outback install this summer ..... expect a write up.
Kris
Kris
I just ordered one of these to replace the comp on my PacBrake system.
http://cgi.ebay.com/ebaymotors/ws/eB...12149358651031
LOL, thanks Chris!
This is what mine sound like now. I plan on a bigger tank with the new compressor, so I'm looking to get more honk time:
Please, please, PLEASE ..... do NOT waste your cash on the Kleinn. They're an okay horn at best, the warranty isn't what it should be compared to other horns I've seen, and you can't get replacement parts (diaphragms and cushions) if you need them.
Spend a couple bucks more and get a complete kit from HornBlasters, or start with a "horn only" kit like this one (I highly recommend this one):
http://www.hornblasters.com/products...train-horn-kit
Then you just add the tank and compressor kit to it and you'll be set.
-Kris
I'm using the cheap Harbor Freight pump, seems the same quality as everything else on the market, but for way less money. I found my horn on Craigslist (nice metal one, dual trumpet) and a tank laying around from a friend. I am into my setup about $100 and it works great. A lot cheaper than the kits on the internet.
