? about underhood mounting...
Old Nov 30, 2005 | 11:40 AM
trik396's Avatar
I'm going to try to mount a Motorguard bypass filter unit in my engine compartment. It's slightly larger than a roll of toilet paper. I've picked a location on the passenger side firewall. I'll make a bracket to hang the unit while still having access to tranny dipstick. It should be a good spot. My question is, I'd like to use some self-tapping screws in the firewall in that general location and I'm not sure exactly what is behind that area, and if it's ok to do this. I wouldn't think anything is directly behind that sheetmetal??
Any advice is appreciated...
Old Nov 30, 2005 | 02:17 PM
underwoodtransp's Avatar
if you do a search on here you will find that a member on this site makes a bracket to just bolt to the exhaust manifold. It is for the amsoil dual remote setup but should easily be modified to work for your particular setup.. I don't know what is behind the firewall myself so I just thaught you would like to know there is another option..
Old Nov 30, 2005 | 03:17 PM
trik396's Avatar
Thanks.... will do.
Old Nov 30, 2005 | 04:32 PM
bbhzx12's Avatar
All of the heat and ac system is behind the pass side firewall so be really carefull before penetrating the sheet metel.
Old Nov 30, 2005 | 04:52 PM
John Faughn's Avatar
I'm going to mount my dual bypass behind the ft. bumper under rad. lots of room and away from the heat .
Old Nov 30, 2005 | 07:09 PM
trik396's Avatar
I've looked at Lightmans' and some others mounts and I'm probably going to fab up something to mount it similarly. Thanks to all...
alvinator
Jun 6, 2003 11:51 PM
Striper
19
Apr 20, 2003 06:20 PM
Jan 25, 2003 05:45 AM
