72 MPH vibration fixed!:D
Old Aug 22, 2004 | 10:08 AM
100 Proof's Avatar
From: Eagle, Idaho. Please set your watch back 20 years when entering.
Talking 72 MPH vibration fixed!:D
I've had the vibration at 72 MPH since the truck was new. Because of speed limits where I do the vast majority of my driving, I don't typically drive near that speed and have basically ignored the problem. Recently, my truck developed a leak at the rear of the transfer case that appeared to be the driveshaft seal. I took it in to Sundance Dodge in Boise for repair and it turned out it was leaking through the yoke, not the seal. On mine, the yoke has a balancer that looks like rubber mounted harmonic balancer one would typically see on the front of a crank shaft. They replaced the yoke assembly under warranty.
Yesterday, I snuck the truck up to 75 MPH (in a 55 zone) and the 72 MPH vibration was gone! I'll get the truck up on a freeway in a couple of days for some extended driving at 72 and higher speeds to see how it behaves.
TTFN....
100 Proof
Old Aug 22, 2004 | 11:10 AM
Dave65's Avatar
Congrats,just like having a new truck again
Old Aug 24, 2004 | 11:37 AM
Chillimau's Avatar
I'm glad yours is fixed! But I hate to hear that cause mine doens't have the vibe but the yoke is leaking! Just great, change the yoke to fix the leak and get a vibe. That would be my luck.
Old Aug 24, 2004 | 11:45 AM
100 Proof's Avatar
What's up with these leaking yokes? I've never ever heard of that happening before, and I've been around...
100 Proof
Old Aug 24, 2004 | 12:38 PM
SHARPMACHINE's Avatar
cheap parts. lots of chubbies had them in the 90"s..
Old Aug 24, 2004 | 12:51 PM
sawboywv1's Avatar
clean with brake clean around the welch plug at the rear of the yoke and coat with a good silicone sealant. that will cure the leak. fixed many like that.
Old Aug 25, 2004 | 07:19 AM
Chillimau's Avatar
Thank you Sawboywv1. I was thinking about using some epoxy glue to fill the seam around the welch plug, just didn't really know if that would last long term.
Thanks Gary
Old Aug 26, 2004 | 12:29 AM
ttreibel's Avatar
Thanks for the tip my yoke only seems to leak when i am towing with heavy tounge weight The dealer couldn't find the leak big suprise.....
I think I should take all my scratched Safety glasses and paint the lenses black and sell them to Dodge as "diesel tech inspector glasses" then i could afford there 30 dollar a quart mystery oil....
treemonkey
Jun 17, 2009 02:06 AM
msatow
21
May 16, 2005 10:44 PM
v8440
Jan 5, 2005 07:07 PM
Mark Hodowanec
Nov 13, 2004 11:02 PM
Mark Hodowanec
Nov 10, 2004 06:41 PM
