6Spd RPM bounce
Old Nov 25, 2013 | 05:12 PM
BothellDiesel's Avatar
6Spd RPM bounce
I've had this issue for awhile but decided to post because Ive heard different opinions on other forums. Example: Im traveling at highway speeds and come to a red light. I let off the throttle and put the truck into neutral. The tack goes down below 1k RPM to 750 then bounces up to 850-900 a few times then settles back down to 750 and stays there. I do not have a programmer but I have an Arson II (No modified cascade valve). Is this what other manual transmission guys see as well?
Old Nov 25, 2013 | 05:57 PM
madhat's Avatar
Administrator/Jarhead
Can you hear the engine doing this, or is it just tach?
Old Nov 25, 2013 | 09:07 PM
Spooler's Avatar
It could be the modified FCA causing this. It's possible. They can do strange things.
Old Nov 26, 2013 | 12:16 AM
StealthDiesel's Avatar
My truck has done this since new, when it was stock and now with a Smarty programmer and modified CP3. I consider it totally normal and not a factor..
Old Nov 26, 2013 | 07:55 AM
AH64ID's Avatar
Mine holds about 850 until I get below a certain speed, it is to improve the braking and steering power.
The bouncing is probably the ECM trying to accommodate for the 90's and modified FCA as well.
Old Nov 26, 2013 | 08:23 AM
DragonSlayer's Avatar
I don't think my truck is tuned, it has a new FCA, and it bounces like that. I have not paid any attention to the listen to see if engine is actually going up and down.....but I think it is. Also if I'm running around 25mph and take it out of gear, the rpm stays up a little and then drops to idle as I apply brakes. Thought it was just the engine computer.
Old Nov 26, 2013 | 09:31 AM
I figured it might be the FCA or the truck is dumping left over rail pressure
quicksilvr
Jun 21, 2010 01:33 PM
westport
Nov 24, 2005 01:43 AM
norsk
Jul 19, 2005 08:26 PM
bauer500
Nov 15, 2004 04:24 PM
fishin fever
Feb 22, 2004 08:32 PM
