6 speed Shifter Knob
Old Nov 24, 2003 | 03:11 PM
TexasTodd's Avatar
6 speed Shifter ****
Why does this thing work it's way around so it does not point to the gears, and you can't turn it by hand????
Old Nov 24, 2003 | 03:26 PM
Bradley's Avatar
Re:6 speed Shifter ****
I don't know, but mine is doing the same thing. I was thinking about taking mine out and gluing it so it want turn anymore.
Old Nov 24, 2003 | 03:37 PM
Dr. Evil's Avatar
Bradley you are right - its not the entire **** thats turning - its just the indicator. Carefully pry it off with a small screwdriver, apply a bit of rtv and put it back in. This will solve your **** problems.
Old Nov 24, 2003 | 04:18 PM
RamDan03's Avatar
In my rig, the entire rod loosened. I just pulled up the console and gave it a good tightening. I have heard of other people who have had just the indicator part of the **** move too. Mine hasn't budged....go figure ;D
Old Nov 24, 2003 | 04:26 PM
Dr. Evil's Avatar
Dan thats kinda strange....never heard of that before........In most cases its the indicator spinning...
Old Nov 24, 2003 | 06:16 PM
Mexstan's Avatar
TexasTodd, just for fun do a search and find the original thread on this subject. You may get a kick out of some of the answers. Seem to remember that it is quite long.
Old Nov 24, 2003 | 08:29 PM
spots's Avatar
Pull it out, hack some notches in it, stick it back in and it will stay put. Then if for some reason you decide to remove it, it will come out. I did mine while I was waiting at a drive thru.
Old Nov 24, 2003 | 10:17 PM
RamDan03's Avatar
[quote author=Dr. Evil link=board=20;threadid=22817;start=0#msg213669 date=1069712761]
[/quote]
Yeah, I guess mine was a special situation.
cwg's Avatar
cwg
mine is 180 off with only 3800 miles.
i took the boot off the other day to see what was turning. it's not the **** or the indicator, but the center part of the shaft. it's a two piece shaft that's rubber filled to cut down on virbration. it looks like the only way to fix it from spining is to pin it an inch or 2 above when it threads on the shifter coming out of the trans, but then you'll feel even more vibs at 70. mine has not turned anymore in the last 2000 miles so maybe it's turned all it can and the rubber is set. pulling the **** and straighting it sounds like a good idea after the rubber sets.
or you could glue a beer bottle cap to it, so you can't read the numbers.
Old Nov 25, 2003 | 12:43 AM
Dr. Evil's Avatar
[quote author=cwg link=board=20;threadid=22817;start=0#msg213854 date=1069733872]
[/quote]
Hey thats my idea.....I think one of my first posts on the DTR.
Old Nov 25, 2003 | 12:45 AM
Dr. Evil's Avatar
[quote author=RamDan03 link=board=20;threadid=22817;start=0#msg213851 date=1069733826]
[/quote]
[/quote]
I guess the shifters in the 98-2002's are different......
Old Nov 25, 2003 | 06:44 AM
JKE's Avatar
JKE
pull out the insert and push in a beer top. Fits fine and will not rotate....you will have to guide in the flutes of the cap first....do not know who thought of that first. It works...pick a beer any beer.....mine has not rotated since.
Old Nov 25, 2003 | 08:43 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
With almost 14,000 miles on my truck....mine still hasn't moved. Funny thing is....from the day I got it the diagram was angled so it was facing the driver's seat. Everyone I've ever seen before was straight up and down. :-
Old Nov 25, 2003 | 07:32 PM
spots's Avatar
[quote author=Hoss link=board=20;threadid=22817;start=0#msg213981 date=1069771404]
[/quote]
Your truck probably had the speedo rolled back. Or was written off.
Old Nov 26, 2003 | 11:04 AM
Hoss's Avatar
Probably.
