4X4 Shift on the Fy
Old Jan 29, 2007 | 04:46 PM
Mark Hodowanec's Avatar
4X4 Shift on the Fy
I don't normally shift on the fly, but today I did. Just came off the interstate & their was fair amount of snow & ice. I was doing about 15 mph & pulled it into 4-Hi. I could hear gears grinding & immidiatly backed off. Came to a stop & put in 4-Hi. It was cold out - about 7F, but the truck was full warmed up.
Why did my truck do this? Because of the cold?
Old Jan 29, 2007 | 04:58 PM
oneslowyfz's Avatar
from what i understand you are supposed to **** 4 wheel high while moving just not passed speeds of 50mph you are supposed to let off the accel. firmly shift into 4wheel high. now for 4 low is a diff story you are supposed to put it in gear start moving do not exceed 5 mph put it in N firmly shift into 4low do not pause in N, one movement from 2w to 4lo, then put back into drive and you are in 4 low some ginding is normal but excessive should be concerning! i dont understand how you can stop the vehicle and put it in 4wd mine will not let me at all
Old Jan 29, 2007 | 05:10 PM
Smokeman's Avatar
Wheels spinning?
Old Jan 29, 2007 | 05:27 PM
bulabula's Avatar
Mark, I usually always shift on the fly from 2H to 4H, from just rolling along to flying down the highway. My transfer case is tough to shift when stopped. I've never gotten a grind out of it unless I was having a brainfart and babying the lever into 4H, or trying to push it into 2L when I was moving to fast.
Old Jan 29, 2007 | 06:00 PM
Originally Posted by Smokeman
Wheels spinning?
I think I backed off skinny pedal before I yanked the lever, but can't be 100% sure. Hopefully that's all it was.
Old Jan 29, 2007 | 08:53 PM
RamWheelsBy4's Avatar
I have shifted mine at 25mph before without any grinding.
Old Jan 29, 2007 | 10:59 PM
stock03's Avatar
Mine has "clunked" hard when I was spinning the rear tires. I bet that's all it was on yours too.
Old Jan 29, 2007 | 11:11 PM
Mopardan's Avatar
I have shifted mine into 4hi many times @ 50mph with no grinding. I let off the skinny pedal, pull it into 4hi, and back on the pedal.
Old Jan 29, 2007 | 11:21 PM
stock03's Avatar
That’s exactly how it’s done!
Old Jan 30, 2007 | 12:39 AM
morkable's Avatar
i shift mine in and out of 4 hi all the time at varrying speeds, the only time that it will make noise is if I do it while one or more tires are spinning, or I am in a corner situtation
Kevin
Old Jan 30, 2007 | 01:41 AM
cairo glenn's Avatar
That's interesting about the difficulty of shifting into 4 high while stopped; mine has no problems or grinding either while stopped or rolling, but I've never tried to shift into 4wd while going any faster than about 20mph.
Old Jan 30, 2007 | 05:30 AM
Timmer's Avatar
iv shifted meny times in and out of 4high at all speeds, from standing still, all the way up to 70 mph with no prob. might have just been one of thows things that it just wanted to grind. bet it dont hapen again.
Old Jan 30, 2007 | 05:33 AM
Kevin
Will it make noise if your in a corner, even if your off the throttle?
Old Jan 30, 2007 | 11:08 AM
ptgarcia's Avatar
I shifted out of 4HI into 2wd once on the freeway at 70mph with no noise. My truck has the electronic shifter thingy.
Old Feb 17, 2007 | 11:45 AM
1badTTA's Avatar
Yup, the front axle is going at a lower speed than the rear axle so when you try to lock the two together the speeds don't match and it grinds, same thing for when you are spinning the rear wheels but not nearly as bad.
itr.#1446
Nov 9, 2008 09:03 PM
MoparRiggan
29
Nov 9, 2008 12:02 AM
V.R.Wheeler
Aug 4, 2007 01:00 PM
poogan
May 4, 2007 08:47 PM
CASMOKIN
Competition / Pulls / OffRoad
Dec 30, 2005 01:28 PM
