48re shifting questions
Old Mar 17, 2009 | 11:40 AM
HIGHGEAR's Avatar
From 1st-2nd,2nd-3rd it shifts hard but from 3rd-4th,4th-OD it shifts light. Is this normal or is something out of adjustment.
Old Mar 17, 2009 | 12:50 PM
no_6_oh_no's Avatar
Sounds normal for a built trans and Shift Enhancer. Its better for the trans that way.
Old Mar 17, 2009 | 01:12 PM
HIGHGEAR's Avatar
If you don't mind me asking, but why is that better for the trans no 6 oh no.
Old Mar 17, 2009 | 05:21 PM
no_6_oh_no's Avatar
A quick firm shift spends less time spin the clutches against the steels and burning thru the oil on them. The cluches are designed to cushion the shift by slipping on the steels with a film of oil until the clamping force takes over. The lack of pressure and slide shifting ends making too much heat and friction and chewing the clutch material off faster than it should. Yes, the correct shifting action is in direct conflict with all the NVH endeavors.
That said, a shift should be firm and positive but not neccessarily knock dust off the headliner. Not that is bad but it can get old after a bit.
Old Mar 17, 2009 | 08:08 PM
HIGHGEAR's Avatar
Hey thanks no 6 oh no, just trying to get alittle educated.
Brendan
Oct 17, 2007 11:12 AM
98 Ram 24V
Dec 24, 2005 10:19 AM
bigtobe
Oct 28, 2003 03:19 PM
dansdad
Sep 6, 2003 09:00 PM
courtndd
May 29, 2003 05:07 PM
