48RE orderable!!!!!!!!!!!!!!!!
Old Dec 5, 2002 | 05:36 PM
Luke S's Avatar
I can order em today. I ordered mine just 2 minutes ago. $1095 option in addition to HO engine. OK, who wants my other 03', do I hear $32,500, now $32,600 WooooooooooooooooooooHooooooooooooooooooo
Old Dec 5, 2002 | 05:44 PM
phox_mulder's Avatar
Re:48RE orderable!!!!!!!!!!!!!!!!
What will ya give me for a slightly used, unbombed 2002?<br>Only 11,500 miles. See sig.<br><br>Or, better yet, can ya order me a 48RE for said 2002? ;D.<br><br><br>phox
Old Dec 5, 2002 | 06:19 PM
KenR's Avatar
Tell me more. I just talked to my dealer today and he knew nothing.
I went to the Dodge site and they are not available.
Please give details.
Old Dec 5, 2002 | 07:43 PM
dealseeker's Avatar
&quot;ETHEN S&quot;...what's this? New truck so a new name to go with it? ETH...ENS?
Old Dec 5, 2002 | 08:34 PM
So, that's it.
I guess if you change your name, it changes on all your previous posts as well.
Learn something new everyday.
phox
Old Dec 5, 2002 | 09:32 PM
FiverBob's Avatar
Sure would be nice to know what a 48RE is before someone has to order it. <br><br>6SpeedBob
Old Dec 6, 2002 | 08:41 AM
Luke S's Avatar
I don't know what the heck happened with my name ??? My 11 year old brother &quot;Ethen&quot; was messing with the computer when I left work last night. I'm gonna ring his neck &gt;
Old Dec 6, 2002 | 08:52 AM
Luke S's Avatar
I did not know about this until 5:30 pm central time last night. I was specking out a truck for a local farmer and I noticed the word 48RE on the screen where you select the drivtrain. I had to do a double take because I had looked earlier that morning and nothing was there. It is strange though, you can get the 48re with the SO or you can still get the 47re according to my computer. It could just be a computer glitch though. Also for those who care the 48re is the only auto it shows for the V-10 : ???
Old Dec 6, 2002 | 09:11 AM
Sarge1124's Avatar
[quote author=Luke S link=board=20;threadid=7920;start=0#76517 date=1039186361]<br>I did not know about this until 5:30 pm central time last night. I was specking out a truck for a local farmer and I noticed the word 48RE on the screen where you select the drivtrain. I had to do a double take because I had looked earlier that morning and nothing was there. It is strange though, you can get the 48re with the SO or you can still get the 47re according to my computer. It could just be a computer glitch though. Also for those who care the 48re is the only auto it shows for the V-10 : ???<br>[/quote]Hi Luke, now that the 48RE can be ordered, when do you think that DC will give all the specs on it?
Old Dec 6, 2002 | 09:31 AM
KenR's Avatar
Hi Luke,
Can you order the Jake Brake with that transmisison?
Old Dec 6, 2002 | 09:32 AM
Luke S's Avatar
Knowing them probably about 6 months after they hit the lot Hell, I figure it's gotta be better than the 47re so I just said what the heck and ordered one. I really wanted the feel of 555ft-lbs. under my right foot too. 8)I got a nice pretty 03 S.O. if anybodies lookin 8)
Old Dec 6, 2002 | 09:35 AM
Luke S's Avatar
Ken, not from the factory. But my sources say through the grapevine the 48re is Jake brake compatible, who knows ???First I gotta get some darn Jake brakes. I got 5 of em ordered for guy's with hand shakers and they have been back ordered :'( :'( :'(
Old Dec 6, 2002 | 09:36 AM
KenR's Avatar
Found these specs on Allpar.
47RE / 48RE four-speed automaticsThese older transmissions are heavy duty for the V-10 and standard Cummins (47RE) or heavy duty Cummins (48RE). Transmission: 47RE/48RE - Automatic, Four-Speed Overdrive
Availability: 47RE - Optional with 8.0-liter V-10 and standard-output Cummins diesel engine
48RE - Optional with 8.0-liter V-10 and standard-output Cummins diesel engine
They feature hydraulic control, with electronically controlled governor overdrive, overdrive lockout and converter clutch.
Gear Ratios:
1st: 2.45
2nd: 1.45
3rd: 1.00
4th: 0.69
Overall Top Gear Ratio: 2.57 with 3.73 axle ratio and 2.82 with 4.10 axle ratio
Old Dec 6, 2002 | 09:43 AM
KenR's Avatar
From Shade Tree Mechanic web site<br>TRANSMISSIONS<br>48RE FOUR-SPEED AUTOMATIC TRANSMISSION<br>The 48RE automatic transmission will be optional on 2500 and 3500 series with both <br>Cummins diesel engines and with the 8.0-liter gasoline engine beginning in January 2003. It is a beefed up version of the 47RE automatic transmission, which it replaces. Extensive internal modifications give it the torque capacity and durability required to work with the redesigned High Output Cummins diesel engine. This is the first automatic transmission available with the High Output engine. The internal modifications also give the transmission a design life of 150,000 customer-equivalent miles. Contributing to the durability and long life is electronic torque management - limiting engine torque build up when initiating acceleration from a stop. The 48RE transmission retains all the features of the 47RE, including the electronically controlled governor, and the same gear ratios.<br>For states that require vehicles to meet the California Emission Standards, the Cummins Turbo Diesel exhaust system includes a single underfloor catalytic converter. For those states which do not require vehicle to meet this standard the converter is replaced by an exhaust resonator.<br><br><br>
Old Dec 6, 2002 | 09:49 AM
Luke S's Avatar
That right there is more info than anything I have at the current time.
