48re cracked overdrive housing
Old Sep 28, 2010 | 10:02 AM
IH8DODGE's Avatar
Sounds like the output shaft does not have enough play.. There is a write up on this on the Goerends website. I will see if I can find and post
Ok sounds like I need to quit messing around with this trans and just buy a built one. Plus have the drive shafts balanced.
How much does he sell them for and does he install them?
Thanks abunch
Old Sep 28, 2010 | 11:33 AM
DBLR's Avatar
Does your truck have a carrier bearing, if so you may want to look in to buying a one piece drive shaft.
Old Sep 28, 2010 | 04:13 PM
j-fox's Avatar
Originally Posted by IH8DODGE
There is a small vibration around 70mph but was told that was my tires, might not be tires. all u-joints and front hub bearings have been changed.
I'm a ford guy and the only reason I bought this truck was for fuel economy and for my wife to drive cause she dose'nt like driving my f350 crew cab dually. Wife says "The ford has a steering radius of a school bus and the dodge is a pretty truck that turns so much sharper".
Anyhow I would realy appreciate any sugestions.
That vibration at 70 could be the OD assembly. someone took it apart without marking it. It was balanced as an assembly.
Old Sep 30, 2010 | 07:33 PM
Mcmopar's Avatar
Thanks abunch
Call Dave, I'm his NC installer and can tell you he stands behind his stuff like no other. You need to be really honest and explain what has been happening. Goerend Transmissions 563-778-2719. If you want tell him Phil from NC sent you.
McMopar
Old Sep 30, 2010 | 08:46 PM
bigdave's Avatar
If it is a one piece drive shaft, have you looked at the splines where it is supposed to slide freely in and out of the transfer case? Or maybe the drive shaft wasn't built right and is just a little too long and is bottoming out.
Old Oct 1, 2010 | 11:37 AM
Eric @ ATS's Avatar
Check the rest of the driveline, specifically like these guys have said about the driveshaft & t-case. Take the driveshaft somewhere that rebuilds them & have them work it over w/ a balance.
I'm leaning away from transmission primarily because it has not been the same transmission throughout (assuming the shops were telling the truth when they told you they replaced case), which should rule out flawed castings, bent shafts, etc.
warren557
Oct 15, 2011 11:20 AM
1fatxl
May 31, 2011 04:54 PM
klx650a2
Apr 20, 2009 05:25 PM
ShawnQ
Mar 10, 2008 10:41 AM
WVPANHANDLER
Feb 1, 2003 08:23 PM
