47 re lock up
Old Jun 27, 2009 | 10:26 PM
dakotajam's Avatar
47 re lock up
I have heard from a few that a 47re will lock up in second gear if manualy put in second. any truth I even get different answers from dealers.
John
Old Jun 27, 2009 | 11:21 PM
.boB's Avatar
This is what it says in the factory service manual:
The torque converter clutch is hydraulically applied or released when fluid is feed or vented from the hydraulic circuit by the torque converter control (TCC) solenoid on the valve body. The torque converter clutch is controlled by the Powertrain Control Module (PCM). The torque converter clutch engages in FOURTH gear, and in THIRD gear under various conditions, such as when the O/D switch is OFF, or when the vehicle is cruising on a level surface after the vehicle has warmed up. The torque converter clutch can also be engaged in the MANUAL SECOND gear position if high transmission temperatures are sensed by the PCM. The torque converter clutch may disengage momentarily when an increase in engine load is sensed by the PCM, such as when the vehicle begins to go uphill or the throttle pressure is increased.
Old Jun 28, 2009 | 09:26 PM
dakotajam's Avatar
Thanks .boB
JKM
Sep 23, 2007 11:38 AM
xp8103
Jun 2, 2006 07:00 AM
mr T
21
Jun 1, 2005 08:48 AM
Nuttymopar
Sep 2, 2004 07:39 AM
damon_achey
Jun 7, 2004 03:33 PM
