4 inch exhaust
4 inch exhaust
I read a thread that said the 03 exhust was only 4 inch after the muffler. Is this true? I haven't measured mine but I assumed it was 4 inch from the turbo outlet to the tail pipe.
Re:4 inch exhaust
[quote author=deere nut link=board=20;threadid=18238;start=0#msg170890 date=1060561553]
[/quote]
To be exact, the turbo outlet is 4 inches. It tapers down to 3.5 inches to the inlet of the muffler. The outlet of the muffler all the way back to the tail pipe is 4 inches.
[/quote]
Re:4 inch exhaust
Deerenut,
I haven't been inside the 2003 muffler yet but in all the previous ones the interior of the muffler has the tubing at or below 2.5 or 2.75 inches. The neck down as you enter the muffler to 3.5 inches is only the beginning of the restriction. The Ford is the worst it necks down to 2.5 inches and then makes 2 180 degree turns through two sets of non tubing baffles, and really small 1/8th inch or less louvers, you can't blow anything thru it!
Mark @ DPPI
Mark @ DPPI
big_bear_92007
41
May 18, 2007 08:11 AM
cumminsdriver635
22
Mar 19, 2005 05:09 PM
