3rd gear in a 03 6 speed?
I have a 03 3500 6sp CTD. While pulling my toyhauler(14500#) as soon as I shift into 3rd it goes fine for 3 seconds then acts is if something is slipping, shift into 4th,5th and 6th and everything is fine. Does anyone know what the problem is? Thanks
I've NEVER heard of this type of issue with the NV5600. In fact, the only problem you'll ever really hear about it shift quality-- problems with it are very rare.
What exactly do you mean by "acts like something's slipping"?
Originally Posted by MikeyB
Hard to believe it's slipping in third gear. Clutches usually slips in the higher gears. Have you tried turning off the Edge? Could be the Edge doing it's torque limiting.
MikeyB
MikeyB
Same slippage felt at all 3 levels. Anybody?
Art,
This switch setting info is from the Edge manual for the defueling when detecting transmission slip.
x=off 1=on
Standard with 3.73
xx1 - Defueling on
x11 - Defueling off
Standard with 4.10
1x1 - Defueling on
111 - Defueling off
MikeyB
x=off 1=on
Standard with 3.73
xx1 - Defueling on
x11 - Defueling off
Standard with 4.10
1x1 - Defueling on
111 - Defueling off
MikeyB
Thanks Mikey, further inspection of me looking under the truck I have found what seems to be engine oil on the bottom of the tranny bell housing, must be rear main I would assume. Second could that be a cause of the slip if the clutch is wet with oil?
I believe if the clutch material was contaminated with oil it would be slipping in every gear.
Check the valve cover gasket area for oil. Could be leaking from there and running down the back of the block. Common problem on the '03 trucks.
MikeyB
MikeyB
It still ought to be slipping in 4th and 5th more than 3rd. In any case, I just priced some clutches from southbend. A good single disk would have run me about $1100. I opted for the Clutch Of Jesus, a dual disk rated to 650 hp, because I'm gonna put twins on it eventually. That setup was $2500 delivered. Now, that includes a new oversized flywheel, an oversized cryogenically treated input shaft, and a new clutch slave and master cylinder to reduce pedal pressure. Most likely, you won't need all of that stuff. Peter at southbend is very helpful, by the way.
anonymous_1
13
Apr 30, 2020 04:29 PM
whtractor
Aug 2, 2010 10:27 PM
buckman361
Oct 10, 2008 11:23 PM
1qckdodge
Mar 5, 2007 09:53 AM
Maccandy
May 6, 2004 10:41 AM
